Try going to a different picture setting
SOURCE: Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
SOURCE: black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
SOURCE: Picture is squeued vertically from top to bottom.
check for dry joints around the main chassis,esp the supply lines .
SOURCE: Why do we have black bars on top and bottom of screen
Originally when 16:9 TVs were produced movies were being shot in 16:9 so that you had a full screen. Now they are being shot in 14:9 as it gives you a more cinematic experience. This is due to the fact that colours look more vibrant when they are placed against a colourless/lightless surface (such as a black panel) as for the bars on the side of the screen LuciferStarr is correct; it depends on the format in which the video was originally produced. For example most older television shows are still shown in 4:3 but newer shows and movies are produced in the widescreen format.
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
