Question about Maytag Refrigerators
SOURCE: Maytag refrigerator, Model MSD2454GR
Your best bet is to shut the unit down for a while and let it defrost. You've probably got your box set too cold. 0-5 degrees on freezer...38-42 on fridge side. If your unit is not digital, use a regular outdoor thermometer, close the door for half an hour and then open to read it. Adjust accordingly. If too cold...you're using too much energy, too.
Posted on Jan 03, 2008
SOURCE: Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Posted on Nov 26, 2008
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
SOURCE: Maytag refrigerator model #MFD2561HEW -
Hello, Thank You for using FixYa. I will be helping you today. Your water tank is frozen! Itson the back wall of the fresh food section if you look behind the drawers you will see it. Use a hair dryer and heat it untill you get water out of the dispenser. This is a common issue with this model.
Thank You and please rate my answer if it was helpful..
Posted on Jun 09, 2011
Jan 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Jan 16, 2010 | Maytag MFC2061HES Stainless Steel French...
Nov 11, 2009 | Maytag Freezers
Jul 29, 2009 | Maytag MFC2061HES Stainless Steel French...
Mar 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Jan 12, 2009 | Maytag MFC2061HES Stainless Steel French...
Jul 25, 2008 | Maytag MFC2061HES Stainless Steel French...
May 15, 2008 | Maytag MSD2756GES Side by Side...
Dec 22, 2007 | Maytag MFC2061HES Stainless Steel French...
90 people viewed this question
