Question about Kohler Electrical Supplies
I NEED A WATER PUMP FOR A KOHLER GEN 7.5R27, S/N 028312, SPEC # 106181
Posted by JOHN BELDING on
Bill Boyd
    Top Expert:
  • Kohler Master
  • 53,801 Answers
Get it from a Kohler service agent spares
Posted on Jul 26, 2018
1 Related Answer
Anonymous
  • 437 Answers
SOURCE: need flywheel K161T tiller 7 hp kohler
Go to www.precisionope.com. Find Kohler under OEM parts.
Good Day.
Posted on Oct 07, 2009
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Kohler RXT won,t start Kohler 20resa
Did you check the remote terminals and relay in the ATS, disconnect gen remote wires, kill the ATS brealer and ohm across the start terminals, they should close, if not a relay/control board issue, if they do fault is in wiring or gen control, or incorrect wiring
Jan 03, 2013 | Kohler RXT-JFNC-0200A-QS 200 Amp...
Need wiring sch for7CCKMR61 spec 140291 serial 326977
I can maybe help with that, as this is an old post, if you still need it let me know
Aug 31, 2012 | Kohler Electrical Supplies
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
Can I add a inline heater to a Kohler whirlpool 1164?
In looking at the spec sheet for this model, it appears that a heater is already installed at the factory. See this link:
http://www.us.kohler.com/onlinecatalog/detail.jsp?item=9737602&prod_num=1164-H&module=Bathing&frm=null
If the whirlpool isn't heating, the power to the heater, thermostat, and the heater itself should be checked.
Apr 08, 2010 | Kohler Sunward K-1164-H-96 Biscuit 6 Feet...
Need flywheel K161T tiller 7 hp kohler
Good Day.
Oct 07, 2009 | Troy-Bilt Garden
This is paul at Paul's Outdoor Power Equipment. I have a lincoln ranger 8 with a bad Onan engine. Is there a Kohler spec engine I can usne to replace my engine with.
Hi Paul,
I know that you want a Kohler CH18S but I can't find the spec number you need (Kohler web site won't work with my browser), your Kohler engine deal ought to be able to look this up for you.
Carl
Dec 03, 2008 | Welding Tools
Electrical Supplies Logo
66 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
