Question about Furniture
No cap for air mattress on BYO bed queen mattres. No manual
Posted by Audrey Derby on
5 Related Answers
WatsHVAC
  • 35 Answers
SOURCE: Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
http://www.filterqueen.com/pdf/defender.pdf
Posted on May 27, 2010
Anonymous
SOURCE: Help! I converted my Baby's Dream Generation Next
Did you get an answer to your question? I have the same problem.
Posted on Jul 14, 2010
snowghost1
chris wheeler
  • 784 Answers
SOURCE: Hi I have an Airpedic Simmons
well it sounds like there is a leak there somewhere.
there are a few products out on the market that are made to fix small leaks ( just kinda depense on where the leak is ). if the leak is one a flat part of the mattress - the repair kits will work great,, but if it is on a seam - then this will be a bit more difficult to stop. ( but either way it is worth trying to fix ).
first you will need to find the leak -- to do this you will want to inflate the mattress and then take a soapy warm water solution ( dish washing soap works great -- plus the more soap the better ) and with a sponge, rub down the whole mattress. then lay on the mattress ( or put something heavy on it ) and keep rubbing the soapy water around the mattress and on the seams and look for any bubbles that form -- this is your leak. mark area with a Sharpie* or felt pen. now deflate the mattress and dry area and follow the directions on the patch kit ( this will be a vinyl repair kit and it can be bought at your local boat supply shops,, or a pool supply shop,, or a water bed supplier ).. the steps will be to wash and clean and dry area,,, use the scratch pad to ruff up the surface ,, clean area again,, dry and apply glue ( which is basically contact cement ) and then apply glue to patch and then wait about 3 minutes and then put patch on area to be repaired,, apply pressure and hold for a minute or so and let cure for 6 hours. this will fix your leak.
c...
Posted on Feb 11, 2011
demi j
  • 11 Answers
SOURCE: Is it ok to use an air mattress as a permanent bed?
Technically it is but I don't recommend it because they don't give your back the best support.
Posted on Jul 09, 2012
Clive Thompson
SOURCE: how do you deflate the northwest territory queen size air bed
I was confused by this too. Here's the trick:
When you inflate the mattress, you unscrew the square-shaped plastic cap, like this:
But this is *not* the cap you unscrew to deflate it!
To deflate it, you have to unscrew the plastic at the *round* part that's beneath the square cape -- i.e. the part of the plastic that's affixed directly to the mattress. When you unscrew the round part, the entire plastic apparatus detaches from the mattress, leaving a big open round hole where the air rushes out.
It looks like this:
Posted on Oct 25, 2012
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
What do i do when my intex inflatable mattress makes a popping noise and gets bigger on one side?
Sounds like one of the inner chambers is broke, If that's the case you will have to replace the mattress.
Jun 17, 2014 | Intex Comfort Queen Air Mattress - Raised...
Need a replacement valve cap for an Embark Queen air mattress
I went to dirt cheap yesterday and purchased a Embark Air Mattress and once I got it home I discovered that the mattress didn't have a valve cap. I want to know if you could replace the cap without any cost? If you would like to send me one here is my address P.O. Box 282 Blue Mountain Miss 38610 Thanks for your help
Feb 16, 2014 | Embark Queen Pillow Top Double High Air...
What is an air bed?
An air bed, also known as air mattress, is aninflatable mattress (usually by hand). These beds are mainly used at home forguests and come in standard s (queen, king)
Jul 30, 2012 | Furniture
Furniture Logo
240 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
