Question about Johnson Boating
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
SOURCE: 1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
Posted on Sep 20, 2009
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
Posted on Nov 04, 2009
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
Aug 11, 2016 | Boating
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
Aug 17, 2013 | Sierra International 18-4310 Marine...
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Dec 30, 2009 | Boating
