SOURCE: The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Definitely, you'll have to take a look to see if any obstruction is visible. To check the fuses first you'll need to find them. The fuse block cover should illustrate what each fuse is for. You can visibly check the fuses, with a flashlight. Just take a look at the sunroof fuse and check that its not burned. That the metal inside goes from one side to the other and its not burned or broken. You can use a test light or a multimeter, a test-light will do. I usually check them visibly, its obvious when you have a blown fuse just by looking at it. Its better just to pull out the suspected fuse to check it.
SOURCE: clicking noise on door hinge
there is a plastic piece that slides in the center of the door hing if you look close it will be broke or cracked in half. That is what is causing the noise.
SOURCE: location for radiator fan control relay circuit
This relay is a common problem for Chrysler vehicles. Located in the passenger side bumper area (Jeeps). Test the fan first.
Hope helped (remember rated ths help) Good luck.
SOURCE: Where is the horn relay location for a 1995 Jeep
Hi, the horn relay is located under the glove box base that is secured by several screws. Pull the box covering out and you will see the relay box with 6 relays together ( 3 top row and 3 bottom row). The horn relay is located on the bottom row, all the way left. Or the first one on the left bottom row.
