Boot into recovery mode by Holding the Volume + button and hold down the Power button at the same time. As soon as the tablet’s screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume – button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume – button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it’s done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now. If you are running android 5.0 or up, the tablet will likely as for your Google account details...good luck
