Question about Golf
Need electrical schematic for 2005 txt 36v ezgo cart
Posted by Ron Kisner on
Tom Chichester
    Top Expert:
  • 56,040 Answers
Request the schematic diagram from the manufacturer/distributor.
Posted on Jul 26, 2018
Testimonial: "Thanks for your reply but I’ve tried going to their website with no success."
5 Related Answers
Anonymous
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
golfcartman
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
KAComstock
Kelly Comstock
  • 274 Answers
SOURCE: i have a 1999 ezgo
You need 4 12v deep cycle batteries. If you have an old one use that to get the proper dimentions. They are usually the same size that is used in a small car. You can get those at any auto parts store.
Have a good day!
Posted on Apr 19, 2011
Yogi B
  • 51 Answers
SOURCE: Ezgo txt golf cart was running fine till friend
It depends on the symptoms. I would check (or have checked) the battery compartment, power connections and the electric motors.
And why are you posting the question and not your friend whom broke it?
Posted on Nov 08, 2014
Ted Maxwell
  • 3519 Answers
SOURCE: I have a 1991 marathon ezgo cart 36v I am replacing the potentiometer and need the terminal hok up on the pot i have forgotten them hell getting old is a pain
Hi Thomas:
Can't help you with the pot connections other than in my experience with smaller ones, there were only 2 wires and they were isolated from the "shell". You could check that with a continuity meter.
Since all the pot is doing is varying the available power, it didn't matter which way the current was flowing through it.
Undoubtedly I am willing to be corrected.
As for the getting old, there are certainly pains, but, there's still enough parts that work that we can play. Guitars, motorcycles, pool,........... Hang in there.
Reply as a COMMENT to this post just for the helluvit.
Cheers
Posted on Jan 12, 2016
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
Ezgo golf cart solenoid will not work. 36v on battery side 28v on controller side. If the resistor is faulty will this cause the solenoid not to work?? when I push the pedal?
Solenoid valve is the use of electrical energy flowing through the coil generates electromagnetic suction spool (or self-gravity to overcome the spring) attracted Sectional normally open and normally closed two categories typically used to cut off the flow of oil, water, gas and other substances. With pressure, temperature sensors and other electrical equipment to achieve automatic control. Car Diagnostic Tool
Jan 02, 2016 | EZGO 1995-99 DCX600 Controller 600 Amp...
I need a service manual for an EzGO TXT
Service manuals are sold by EZGO but expensive. You might download some wiring diagrams from fsip.biz and buggiesgonewild.com.
Aug 13, 2015 | EZGO TXT Golf Cart Golf
Ezgo txt golf cart was running fine till friend power washed it
Nov 08, 2014 | Cars & Trucks
Where can I find a owner's manual for 2001 EZGO TXT Series 1394577
check out my friends at GolfCard Kings in Austin Texas. They have manuals and all taxes kamatics. Any of their technical help is always free. As well as their schematics. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Sep 10, 2014 | Golf
Why is the EZgo Charger fault light is on
Have all battery checked
xxxxxxxxxxxxxxxxxxxxxx
Jul 18, 2014 | Dual Pro 36V 25Ah Golf Cart Battery...
Golf Logo
646 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
