Question about Locks & Locksmithing
The top tool box is locked and we can't find the key
Posted by Kathi Reid on
Steve Horne
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
If there is a number on the face of the lock take the number and a pic of the face of the lock and brand of toolbox to your local locksmith
Posted on Mar 23, 2019
1 Related Answer
tmburke
  • 76 Answers
SOURCE: Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool: lost key: Sentry 1100 strong box....
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Jul 02, 2010
My key wont turn to unlock freezer.. it fits in and then i go to turn it and it wont turn
I had a problem with my freezer several years ago, I lost the key. I took a small drill and drilled a small hole in the center piece of the lock, then I used a tap to tighten up in the hole, pushed in and turned, it worked. Of course after that I didn't lock it.
I also used to have a tool box on the back of my pickup. I broke the key in the lock on the tool box. The actual lock mechanism was aluminum, it was easy to drill it out, then I took a screwdriver and opened it. It would still shut and everything, just wouldn't lock.
Use your best judgement on the lock, I can't see anything from here. Just relating some of my experiences. good luck.
May 03, 2018 | Cars & Trucks
Where can I get replacement keys for GX B0709 digital safe
There might be a code on the key lock. Manufacturers can sometimes furnish replacement keys by the code or serial number of the safe. A locksmith could also pick the lock and make a key. Keys are really essential if the electronic lock fails. If the safe needs to be opened without keys, a pro can do this with minimal damage.
Aug 06, 2014 | Safe International Digital Electronic Safe...
I have a snap on tool box that the key turns but the lock wont unlock how can i open the roll away to get at the lock
if you can see the linkage between the top draw and the section holding the lock the only way to see what is going on is to drill the lock out or call your snap on dealer and see if he has a trick to do it
Jun 23, 2012 | Cars & Trucks
I have an omega safe n guard but batteries have run out and i have lost keys any ideas please????
Try raising the temperature of the safe, I put mine on top of the aga lids for an hour . The batteries recovered enough to open it.
Feb 26, 2011 | Safe International Digital Electronic Safe...
No key and forgot numerical code
all electronic safe's come with a key,,,,pull off the center cover in the dile and put the key into the lock to undo it
Jul 28, 2010 | Safe International Digital Electronic Safe...
In Summary:
May 18, 2010 | Safe International Digital Electronic Safe...
I HAVE A SMALLN GX B0709 SAFE. THE BATTERY HAS GONE FLAT, AND I HAVE LOST KEY. PLEASE SEND SOLUTION IF ANY.
I put mine on top of the AGA to heat it fro an hour. This brought the batteries up enough to open the safe. Sounds weird but it worked!
Jan 05, 2010 | Safe International Digital Electronic Safe...
Fwellshave lostkeyandforgtton code Grafter electronic safe number960352
Lost keys AND fogotten code ???? Write to the safe company, if they cant help, there is the option of a metal cut off saw, just rotate and cut always on top !
Oct 28, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
322 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
