Error code list
ALARMS THAT STOP THE DISHWASHER
A1 Want of water
Is the water cock open?
Does the water load solenoid valve work?
Is the water feed flow a min. of 5 l/min?
Is the water inlet filter clean?
Is the load solenoid valve filter clean?
Is the overflow inserted?
Do the tank/boiler pressure switches work properly?
C9 Automatic hood out of order
Alarm codes for automatic hood type dishwasher (see paragraph 9.2.1 Alarm codes for automatic
hood type dishwashers)
C12 Tank level sensor out of order
Are the connectors correctly connected?
Are connector contacts cleaned?
Does the air trap of the tank work correctly?
Is the level sensor broken (replace it with a new one)?
Alarm codes for automatic hood type dishwashers
When the alarm C9 appears, to facilitate fault-finding a parameter providing a more detailed indication has
been introduced.
The parameter is C9 and is found in the ron family.
The possible cause of the anomaly can be found (see next table) according to the value of the parameter C9.
E.g.: With an automatic hood type the alarm C9 appears.
Access the parameter C9 in the ron family.
Assuming the value displayed is:
20 ? During lifting, the current absorbed by the lifting motor has exceeded the threshold. This can happen if
a rack or other heavy material was placed on the hood.
ALARMS THAT DON'T STOP THE DISHWASHER (SHOWN ON THE USER INTERFACE AT REGULAR INTERVALS)
b1 Drain not efficient
Has the overflow been removed?
Is the water drain blocked?
Is the drain pump blocked?
Are the air trap and tank pressure switch clean?
Is there a constriction in the drain tube?
Is the pump breather pipe returning to the tank clogged or constricted?
Does the tank pressure switch work properly?
Is there a hole in the drain tube (only for versions with drain pump)?
b2 Overflow alarm
Is the load solenoid valve blocked? (see electrical wiring diagram - YV1 Filling solenoid valve)
Is the load solenoid valve relay stuck? (see electrical wiring diagram - RL5 relay of AP2 board)
C1 Boiler temperature rise too fast
Does the boiler level sensor work properly? The boiler could be empty.
Are no-original power resistances installed?
C2 Boiler temperature too high
Has the boiler temperature been changed (btC - increased above 90°C)?
Has the software alarm value been modified (bH,)?
Boiler relay/relays sticked (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board)?
C3 Tank temperature too high
Is the feed water above 60°C?
Has the software alarm value been modified (tHi)?
Is the rinse water temperature too high?
Is the tank relay stuck (see electrical wiring diagram - RL4 relay of AP2 board)?
C4 Tank temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST1 Tank
probe)?
Is the temperature sensor connector correctly inserted?
C5 Tank temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST1 Tank probe)?
C6 Boiler temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST2 Boiler
probe)?
C7 Boiler temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST2 boiler probe)?
C10 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor broken or disconnected?
C11 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor short-circuited?
C13 Rinse pump out of order (the water level of the boiler does not decrease)
Does the rinse pump work correctly?
Is there any bottleneck in the hose, that connect the air trap and the board sensor?
WARNING:
Alarms C2, C6 and C7 lock the boiler temperature control.
Alarms C3, C4 and C5 lock the tank temperature control.
In the case of alarms C6 and C7, the boiler waiting phase is not executed (the rinse may be performed
with cold water) and, during the initial warm-up and subsequent rinses ( btF > 0 ), the boiler heating
phase is not executed.
In the case of an open probe error ( C4, C6 e C10 ), the displayed temperature is 10°C
In the case of a shorted probe error ( C5,C7 e C11 ) , the displayed temperature is 99°C.
E1 Communication error
Is the connection between main board and control panel correct? Are the connectors correctly
connected?
Are connector contacts clean?
E2 Tank temperature low
Does the tank heating element work properly?
Are the dishwasher feed voltage and current correct?
Is the relay RL4 (see electrical wiring diagram - RL4 relay of AP2 board) on the board disconnected
or faulty?
E3 Boiler temperature low
Does/do the boiler heating element/s work properly?
Does the possible remote control switch connected to the heating element work correctly?
Is there power at the remote control switch input terminals?
Do boiler relays (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board) work properly?
CAUTION: IF THERE IS A MALFUNCTION ON RELAY RL1 AND THE BOILER HEATING ELEMENTS
ARE FED BY MEANS OF A REMOTE CONTROL SWITCH, THE BOARD DOES NOT
HAVE TO BE REPLACED; JUST MOVE THE BOILER HEATING ELEMENT CONNECTOR TO
ONE OF THE TWO FREE POSITIONS ON THE BOARD.
CAUTION: WHEN ONE BRANCH OF THE HEATING ELEMENT DOES NOT WORK AND THE
OTHER TWO CONTINUE TO FUNCTION, ON REACHING THE SET TEMPERATURE VALUE,
ALARM 3 DISAPPEARS AND REAPPEARS IN THE SUBSEQUENT RINSE PHASE. THIS
ALSO OCCURS WHEN A PHASE IS MISSING.
Dado
