Question about Janome Sewing Machines
I bought a janome 6600p last July. I have been dusting the bobbin case and surrounding area regularly. My manual doesnt address oiling the machine. Can i do this myself?
Posted by Jeanne Hammill... on
  • Janome Master
  • 6,164 Answers
When the sewing machine manual does not call for oiling, then you should not add oil. The sewing machine has sealed bearings and long-lasting lubricant. If you attempt to oil the machine yourself, you could damage the electrical system of the sewing machine. (There is a small computer in that machine for the stitch selection and adjustments.)
I hope this helps.
Posted on Jul 25, 2018
5 Related Answers
techworm
Tony Clayton
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
Anonymous
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
Anonymous
  • 108 Answers
SOURCE: JcPenney 7064 , bobbin case, bobbin and manual ??
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
Anonymous
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
Jimmy
  • 539 Answers
SOURCE: Janome 6600p: E1 error
Look in the absolutely free on screen manual for this model MC6600 by typing web site address into your browser: http://content.janome.com You can download free PDF or just browse the manual contents. hope this helps. Jimmy
Posted on Apr 06, 2012
I have a Janome Horison Memory Craft 8900 SpEd, thread looping on backing side for free motion. DO i NEED Part No. 200-445-007 Janome Bobbin Holder for Free Quilting and Hand-Look Quilt Stitch.
Free motion quilting is a finicky function, much more than most other sewing. Since you are getting loops on the back of the fabric, try increasing the upper thread tension. Tension causes the top and bobbin threads to pull against each other. If the pull is not equal, the threads will be pulled to one side or the other.
If you continue to experience looping under the fabric, it could be that the top thread is not fully seated in the tension disk. Try this:
Remove the top thread completely from the machine.
Be sure to install a brand new sharp needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Retest your machine.
However, if you don't find a fix, $25 for the special bobbin holder is probably a reasonable cost if it takes care of the problem. The reviews seem to be good:
http://www.sewvacdirect.com/janome-bobbin-case-for-free-motion-quilting-fits-models-mc14000-mc6500p-mc6600p-mc11000-mc7700-mc12000-and-more/
https://thequiltshow.com/forum/domestic-sewing-machines/120-janome-mc6600p
"Yesterday I bought a new free motion quilting foot and a bobbinholder (for free motion) for my MC Janome 6600P. I have been quilting all day, and belive you me it is a greate investment!!! :lol: :lol: Its like sewing on butter :lol: :shock:
Free motion Quilting Foot: part no.: 200-442-004 (MC6600P and MC11000)
Bobbin Holder (for free quilting and hand-look quiltstitch): part no.: 200-445-007 (MC 6600P, MC11000 and MC6500)
Bet you would love to have those too if you are doing a lot of free motion! The quiltfoot you can adjust so it works perfectly on your quilt!
:lol: :D :wink: I am sooooo happy!!!!"
https://www.getasquiltingstudio.com/2012/01/free-motion-quilting-tips-ii.html
LOOPS Tension or Speed
Free Motion Quilting Tension Problems
Mar 01, 2018 | Janome Sewing Machines
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Janome memory craft 6500 sewing machine...all of a sudden, the bobbin thread does not attach itself to the needle thread...i have taken off the plate, cleaned out the dust, rethreaded both top and bottom...
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Oct 16, 2011 | Janome Memorycraft 6500P Computerized...
Just want a maintenance manual so I can oil my Elna 740 Excellence sewing machine. Emailed the company, but they tell me just to have it done with service visit once a year. I want to oil the machine...
The manual should show you how to clean out the rotary hook area by brushing it out with a little brush provided in your tool kit. It should also show you how to remove the bobbin case and clean under it. Important: if you haven't removed the bobbin case before, then please take photos beforre you start so you can get it back into the right position when you have cleaned underneath. There may be two red marks on the case and surround to match up but I couldn't actually get a close up image of this model to check this.
Here is image from my Janome 6500 manual for this procedure, it should be similar on your Elna 740.
There is probably also an oiling wick in the centre of rotary hook under the bobbin holder. Remove the needle plate, pressure foot and needle, then take out the bobbin and bobbin holder and underneath is a circular metal part with a hole/depression in the centre. Wick will be inside there, don't mess with it!!. Just brush the whole area out, removing the lint from the brush into your bin. Don't try to blow the lint out with compressed air either.
You can add a drop of good quality clear sewing machine oil to the wick every couple of months or so, but keeping the area clean is equally a good preventative measure.
May 09, 2011 | Elna Sewing Machines
How do I clean my machine?
Start by removing the bobbin cover/throat plate. Using the brush that should have come with your machine, make swift upward strokes to coax all dust and lint out of the bobbin case and feed dogs. If you have a manual showing how to remove the bobbin case, remove it. If you don't have a manual, make sure you know EXACTLY how the case was originally in the machine because they can be the deuce to replace.
With bobbin case removed, again use quick strokes with your machine brush to clean out the lint. You may use a vacuum to remove the deep down lint. If you have the attachments that are small and made for cleaning keyboards etc, use one of them to gently probe into the machine for a deep cleaning. You may also use a cotton swab. Turn your handwheel toward you and wipe dust and lint from any moving parts. You may put a small amount of macine oil on a swab after removing dust. This will help to oil moving parts that are expose. DO NOT attempt to oil any hidden parts.
After cleaning the inside and bobbin case, use your brush or a clean swab and gently check the thread take up leaver and the tension discs.Remove lint and debris but do not oil this area.
This should take care of it and your machine should purr with gratitude!
Nov 04, 2010 | Janome Memorycraft 6500P Computerized...
Machine makes noises and tangles up then jams from the bobbin side I do not have a manual
The bobbin case,shuttle rack and hook,and or feed dog,are in need of cleaning and oiling. Thread,fabric fibers and dust collect during sewing.
Jun 15, 2009 | Janome Sewing Machines
Thread gets caught on bobbin and jams
You may need a new bobbin case if your machine is an older model.. Over time the cases get nicks in them causing thread to catch on it. Have you lubricated the bobbin area? Needs one drop of oil for every ,I believe it is 25 hours of usage. That may take care of it. The oil goes under the bobbin right in the center of bobbin case. Remove your bobbin before applying the oil. i hope this helps you. Good Luck
Jan 08, 2009 | Janome Harmony 2039 Mechanical Sewing...
Oiling a Jonome 6600
Remove the plate and bobbin case, beneath it will be a small round hole in the center. Inside the hole is a fluffy piece of absorbant material called the wick. DO NOT REMOVE IT! Place one drop of sewing machine oil on the wick. While you have the machine opened up, you should remove all the dust. I use the small brush that comes with the machine. Replace the bobbin case and make sure that it is clean too. Replace the plate. Lastly add a couple of drops of sewing machine oil to a q-tip and use it to apply oil to the needle bar above the needle clamp.
If your machine continues to squeek then bring it to a professional sewing machine repair technician and pay for the service to have it professionally cleaned and tune up. It is not worth damaging you machine over a few dollars well spent.
Oct 27, 2008 | Janome Memory Craft 5700
Error; after checking bobbin threads, press start button
This is most probably solved by an adjustment to your bobbin thread sensor, and not something for the home handy fellow......especially without a manual.
Be sure that there is no lint build up in or under the bobbin case as a first measure, and give this area a good clean anyway as normal housekeeping.....this will probably make little difference, but may let you finish any urgent job over the weekend.
When was your machine last serviced ?
2 years or more ?
When was your car last serviced ?
Your best solution is to take it to an authorised Janome Service Centre (make sure they have the Service Manual for this model) and make sure to tell them about the bobbin sensor issue so that it can be specifically targeted during a full service.
This MC 9000 was expensive and the top of the range in it's day and deserves good regular care to work to its optimum for many more years.
Jun 08, 2008 | Janome Memory Craft 9000 Computerized...
Janome 1600p
Moving parts require lubrication it is true, however, if there is an underlying problem that you think "a bit of oil" will resolve, this may not be the case.
There is quite a deal of electronic circuitry which will be adversely affected by indiscriminate oiling, and dismantling or adjusting this machine really ought to be conducted with reference to a Service Manual, particularly the automatic cutter.
Your 1600p is a semi-professional workhorse and I would recommend that it be regularly serviced by a qualified technician to check and maintain optimum performance (how regularly will depend on usage).
You have made a serious investment when you bought this machine and it really deserves & ought to be maintained as you would any expensive item, by a qualified person......you wouldn't send your Rolls Royce to just anyone to check the steering would you !?
A regular home cleaning regime should include bobbin case/hook race (under needleplate) and of the thread tension plates along with any obvious buildup of lint at and around the needle arm and region, near the lamp.
Bargainbox
Jan 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Open Questions:
Sewing Machines Logo
108 people viewed this question
Top Janome Sewing Machines Experts
Irene Tulloch
Colin Stickland
Colin Stickland
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
