Question about Sewing Machines
The White Model 1077 doesn't want to sew. It stays in one place. I have read the manual very carefully.I have done everything right as far as I can tell. Any ideas what is wrong?
Posted by Paulette Lemoine on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: white model 1521 manual
go to the white website & email them from the contact us section. they'll email you back w/ PDF version of manual. they did that for me. goodluck!
Posted on Dec 16, 2008
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: I need a manual for a White sewing machine model 1620-2
try this..
www.2instructions.com
Posted on Apr 28, 2009
Anonymous
SOURCE: step motor error
I am working on a 6003Q right now with this exact problem. The shuddering sound is the stepper motor working, but hitting the movement limit stop. The reason it keeps trying to move is that the sensor has failed. In the case of the machine I am working on, it is the zig-zag stepper motor position sensor that has failed. Elna does not sell the sensor separately, it comes complete with stepper motor, mounting frame, and cable, which is a shame because it is approx. $70 dealer cost for the assembly. The sensor is nothing more than an LED as a "sender" with a corresponding "receiver". There is a blade on the stepper motor drive gear that passes between the two and breaks the beam signaling that the "home" position has been reached. Unfortunately, the sender-receiver pair are sealed in a plastic housing so they are not replaceable. The part number of the zig-zag stepper motor assembly is 395727-69.
Best of luck,
Rick
Posted on Jun 26, 2009
BJ sewing
  • 300 Answers
SOURCE: upper looper will not saty trheaded to sew what
You have to thread the needles last.
1 - Take the threads out of both needles.
2 - Thread both loopers according to the diagram on your serger.
3 - Thread the needles.
If this fails, you need to bring it to a pro for service.
Posted on Feb 12, 2010
ken dourof
  • 980 Answers
SOURCE: Looking for manual for White sewing machine model # 311
try www.sewing-machine-manuals.com and click on relics.
Posted on Mar 28, 2010
What is a never used white jeans machine model 1077 worth?
Umm, an unused old sewing machine sounds like it should be worth a lot, however, in retrospect, machines need to be used and maintained regularly. Most likely the machine needs a thorough service as the oil has probably dried out over time and has/will seize the machine.
Vintage White Zig Zag Sewing Machine Model 1077 Cover Jeans Machine eBay
Jun 19, 2018 | Sewing Machines
How do I thread a white sewing machine model 1777 need step by step
You probably already have some documentation, but if not, here are some:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjG_4zKxZHNAhVDEVIKHYRXCCAQFggmMAI&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F1047_white-1077%2C1088%2C1099-x.pdf&usg=AFQjCNEneDdzHiLZoqEsll_eInKSdGrxgg&cad=rja
White sewing Machine model 1418 (not your model, but most machines thread very much the same)
When threading the machine, ALWAYS RAISE the presser foot during the threading process. This releases the tension disk so the thread will seat properly.
White 1735 Sewing Machine Instructional Video
Jun 05, 2016 | White Sewing Sewing Machines
I can't seem to wind a bobbin. I've done everything in the manual but it just seizes up- doesn't spin.
you placed the bobin upside down
one side is flat the other is keyed
so place the keyed side down
usual fault with winders
bobins are easy... read again the manual slowly
Jun 04, 2015 | Singer 57815 Mechanical Sewing Machine
Using a White model 616 with a twin needle?
singer has a free manual in pdf form for the machine, which can tell you if the machine is capable of using the twin needles
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w616 ) & click search
May 21, 2012 | White Sewing 1866 Mechanical Sewing...
The take up thread lever will not come out far enough for me to thread sewing machine
that is because the thread lever on these machines does not come out, you have to place the thread over the top of the arm and it will find the ****.
then continue to thread your needle.
there is no hole to thread it is very easy when you have done it once, just follow the instructions in the manual carefully.
Mar 05, 2011 | Brother XL-2230 Mechanical Sewing Machine
After depressing the pedal, my White 1077 Jeans Machine will not raise and lower the needle, though I hear something spinning inside. I can hand crank it, but it has a lot of resistance. This problem...
If this model has an engage/disengage feature for the feed dogs, did you engage them before regular sewing?
After 8 - 10 hours of sewing, the needle should be replaced with a new one.
Are you stitching a heavy fabric? A machine will sometimes stall if the fabric is too thick.
Feb 20, 2010 | White Sewing Sewing Machines
Hello I am new to the sewing hobby.My switches were fine during sewing a curtain then under & top stiches are a messed up. I rethread it might do fine 1/4 way down starts all over agian. Don't have a...
Here is a list of the model #s I found 1422 is not included are you shure about the #?
White 1077
White 1088
White 1099
White 1122
White 1202 1213
White 1240
White 1409
White 1411
White 1418
White 1466
White 1477 1488
White 1505 1510
White 1570 Classmate
White 1599 Jeans Machine
White 1600 Speedylock
White 1632
White 1700
White 1717
White 1760
White 1766
White 1787 1899
White 1800
White 1919
White 1955
White 1977
White 2000SM
White 2037
White 2134
White 2137
White 2220
White 2222
White 2837
White 2999
White 3077
White 3355
White 3900 F
White 4075
White 6477
White 7934
White 8000
White 8600
White 8800
White 8910
White Computer Machine
Nov 19, 2009 | Sewing Machines
Sewing Machines Logo
167 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
