Question about Blaupunkt Televison & Video
When playing a movie from a USB stick my 55 inch Blaupunkt tv stops after 2 hours and goes back to the start,very frustrating. Any ideas
Posted by Tony Hegarty on
JR Tan
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 88 Answers
The entire movie has not been recorded of the flash drive. There was not enough GB storage for the movie. Either use a flash drive with more capacity or record the movie on a DVD
Posted on Jul 24, 2018
5 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: LCD TV flickers non-stop
More likely to be bad LCD controller, see sample here: notes: I removed the cover from the board. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: there are more than one version of the board, http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
Be careful when remove the back cover! the switch assembly is attached to the back panel, do not yank too kard to remove the back.
Posted on Jan 04, 2010
Anonymous
SOURCE: usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
Posted on Mar 12, 2010
Anonymous
  • 71 Answers
SOURCE: Interference on Blaupunkt RD4 N1-02
Is it an loud sharp sound which varies according to your speed? May be a power problem - crossing lines. Take it by an auto stereo shop and ask the installer. Make sure they sell your brand. Someone would have to hear the sound in order to fix the problem. Hope this helps!
Posted on Mar 16, 2010
Obertelli
Obertelli
  • 3006 Answers
SOURCE: I plug in the USB
First, try using a different USB stick. If that doesn't fix the problem then your new tv is either faulty or the tv operating system has a bug.
Check the LG website in your country to see whether there are any firmware updates available. If not, then return the tv for refund or exchange, but make sure to try your USB drive on any replacement set in store as it's highly likely to be a bug in your model which will affect all of the other examples as well.
Posted on Sep 22, 2010
Anonymous
SOURCE: i have LCD TV LG
i have the same problem on mine too. the usb icon does not even appear. please someone help!
ASHGRAY.
Posted on Nov 22, 2010
Tip
How to activate USB on LCD TV LG's latest generation (LH2000, LH3000, LH4000)
When I got the TV, the LG LH2000, with a diagonal of 32 inches, I was a little disappointed when I realized
that the model that I bought does not work behind the USB port on your TV . I was explained that it is only
for service (software upgrades and the like). I did not beat your head too much and I accepted the
situation.
What would help me? I miss writing movies on CDs and DVDs. Copy just the files on a USB stick, insert it
into the port behind the TV, go into menu and select USB. It's like a DVD player. These days, I discovered
that I can retire the DVD player, because now I can enable the USB and still use it. How?
In a few easy steps.
1.Press the same time the OK button on remote and OK button on the TV and hold down for about five-six
seconds
2. Asking a password - using the buttons on the remote, enter 0000, then press OK
3. Upper left corner of your screen will show the service menu
Well, here's a little more complicated and should be recommended to strictly limit yourself to three
settings below. WARNING! Where do additional settings without knowing exactly what use, you are solely
responsible for the potential disruption of the TV and also for the possible loss of warranty!
Once the service menu appears, select the third option (number 2, named TOOL OPTION3). Do not confuse 2 with
3. The numbering starts with 0, not 1, will therefore TOOL OPTION3 will be numbered with 2.
In other words, select the option marked in yellow as the image on the right. I suppose you can select with
OK, but I entered in navigation settings press the "right" button on the remote.
Following two settings:
1. Once entered in the TOOL OPTION3 menu, select the EMF (JPEG, MP3) and using the "right" button of
navigation on the remote (to be clear, "right arrow"), select option 1.
2.A second, and final setting is highlighted in yellow in the image on the right. At DivX choose HD.
And now important!, In any form do not press OK from the remote! Press Exit button(Return), located in the
lower right-hand navigation menu.
What happens after these settings have been made? In TV menu will be two new options: Input and USB. We are
interested, at present, USB. What should I do to see movies? In this order:
1.Introduce stick into the USB port on the back of the TV
2.Press Menu button on your remote and select the USB
3.Select movie files (or something like that, anyway you got options for MP3 or photo)
4.se will open a variety of browser, similar to those on DVD players
5.Search for desired movie and press OK
Integrated player in LG television support DivX. I put a stick on an episode of TopGear and I saw with no
problem. Using left-right arrows, you can run the movie. For a typical player buttons (Play, Pause, Stop),
they use those colors (they are marked otherwise) on the remote.
Enjoy.
on Jul 20, 2010 | Televison & Video
CAN"T PLAY MOVIES FROM MY USB ON 32 inch HISENSE TV. What format should the movies be in? Presently they are in avi
i have a 32inch hisense led tv i watch movie using usb but it stop and back to the begining when the movie is over 2hours.. hope you can help me .
Mar 08, 2013 | Televison & Video
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
Jan 30, 2018 | Samsung Electronics Samsung 40" EH5000...
I use my samsung ht-z210 to play divx through usb and 8GB stick. With some divx movies the movie starts, but then the screen goes black for 1-2 seconds (sound and time continue) and then plays on. This...
I can't answer the first part of the question, but the DVD going blocky and jumping sounds like fingermarks or muck on the disc. It could be that when you handle the DVD your finger leaves a mark near the outside edge of the DVD. In future wipe the DVD with a glasses cloth, then handle by the very edge only.
Jul 03, 2017 | Samsung HT-Z210T Theater System
I have a 32 inch RCA LCD TV. when I play a movie, every 2=3 minutes to goes back to the blue screen, and blinks a few times then goes back to the movie. Its with every movie and I dont think it is my dvd...
Probably the Controller unit for the TV. Try hooking it up through a different connection type e.g. HDMI, component. See if that fixes the issue for the time being. If it dies then those ports you used previously are malfunctioning.
Mar 19, 2011 | Televison & Video
My Sanyo LCD 40XR10F TV does not recongnise any mp4 movies i have on my external hardrive or usb stick?? Does it matter what size usb disk/drive/how many files are stored on them for it to play them?
Before you loaded the hard drive, and USB did you run a "Check File System" through the TV? These devices in order to use the "Time Shift Function", have to have pass with "SUCCESS", displayed on the screen. If not the TV will format a 4GB FAT32 filing system for you. The reason your MP4's might not work might be due to a firmware update that no longer supports MP4. You should have been OK if you recorded the material from the TV. Items you record from the TV will not play on any other device. Using the FAT32 format only allows 4GB but, the TV allow 8GB and a external device can be FAT32 format to 8GB. 8GB is only 2 hours of viewing time. So that should give you some idea how little the amount of files can be handled.
Dec 21, 2010 | Sanyo Televison & Video
I plug in the USB drive to my LD650 LCD to watch movie. The movie is played for about half an hour and suddenly the signal goes away, TV displays no signal and then immediately I am taken to select input...
Sep 22, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Jul 26, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
Televison & Video Logo
87 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
