Question about RCA TH1101 MP3 Player
MY MP3 I HAVE A MP3 PLAYER THAT WHON DOWN LOAD FOR ME ..... IT CAME UP I HAVE A I/O DEVICE ERROR
Posted by CHANNEON on
  • da king Dec 02, 2007
    my computer doesn't want to upload sonds to my mp3
ThaMp3Doctor
  • 8,597 Answers
Make sure the hold switch is unlocked first
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check
http://support.rcaaudiovideo.com/downloads.aspx?product=25
for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Posted on May 24, 2008
Eclipse MP3 Player
Make sure the music files are mp3 files, not wma or some other format.
Dec 16, 2013 | Audio Players & Recorders
I have problems with format erros from limewire
Maybe you can check at the end of the music file and make sure they are no other extension. Also, it could be that the mp3 files are encoded into a higher or lower codec which your device cant read. Check properly the files you download.
Aug 18, 2009 | iLO MP3 Player
Format philips go gear mp3 player
There is a support page that explains the format procedure for the SA3125 player. It is available here:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=PH&subrequest=1&mid=Link_FAQs&session=20090130135307_66.249.71.73&desc=Philips+GoGear+Flash+audio+video+player+SA3125+2GB*&view=aa12_view_full.html&list=aa12_list_partial.html&slg=ENG&refnr=0064745&refdisplay=PI_C35_SA3XXX_030&dct=QAC&ctn=SA3125/97
Jan 25, 2009 | Philips GoGear SA3125/37 MP3 Player
Transferring music to device
That error code means that the mp3 player is having a problem retrieving digital rights to the songs you have attempted to load.
The license on the songs that you are trying to download either does not permit transfer to mp3 players - or the license has expired. Use mp3 format songs only, and you will never have this problem. You can read my "Tips & Tricks" article on song formats if you really want more detailed information.
-Tha Mp3 Doctor
Jul 29, 2008 | RCA TH1101 MP3 Player
I have a phillips mp3 player sa6185/02, since last week when | down loaded some music onto the player, I have experienced a problem. When I turn on the mp3 player and go into my music option my play...
Before you send the player off to Philips, try the repair procedure.
Make sure you have Philips Device Manager installed on your PC, and open it.
Press and hold [VOL+] whilst connecting the player to the PC.
Device Manager will report an error with your device.
Follow the on-screen prompts.
NOTE: ALL DEVICE CONTENT WILL BE DELETED.
If the player still doesn't connect then roll-back all of your USB drivers.
Jun 21, 2008 | Audio Players & Recorders
Connection to gogear
Sounds like the firmware is corrupt.
Try this:
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Computer Freezes
Power on again.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Trouble down loading
so basically you are having problems transferring songs to your device? if thats the problem try to format your device using windows media player and then try transfer the songs again...what program are you using to transfer the songs to your device?
Jan 03, 2008 | SanDisk Sansa E280 MP3 Player
RCA TH1101 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
