SOURCE: I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
SOURCE: fluro tube
fluro tubes are rated in watts and they are connected to the length of the tube. ie 20 watt 20 inches---30watt 36 inches and 40 watt 48 inches. Some makers have a triclor fluro that have a higher lumens value but the wattage will be the same.. You will have to compare tubes in the lighting shop.
Because of the fact that more than 90 percent of fluorescent lights sold are the four foot tune, it is much cheaper than any other tube, smaller or larger tubes will cost more.
Aquarium fluorescent lights work just like an ordinary fluorescent light. An anode and a cathode located at opposite ends of a glass tube. Inside the tube there is a partial vacuum and a small amount of mercury vapor which produce a light when energized.
