Question about Friedrich Heating & Cooling
My Friedrich air conditioning unit intermittently flashes fault code 07. The current outdoor temperature has been over 105+ degrees over the last few days. We run the unit at 69 degrees.
Friedrich Model# PDE15K3SB-C
Posted by TerryLCoen on
Henry S
    Sergeant:
  • 301 Answers
Here is the link to error codes Friedrich PTAC Error Codes
Posted on Aug 21, 2018
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Posted on Aug 28, 2007
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Posted on Oct 23, 2007
Anonymous
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Posted on Nov 20, 2008
Anonymous
  • 7 Answers
SOURCE: OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
Anonymous
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
Wiring diagram, friedrich model em18l34-c window a/c
Request the wiring diagram directly from Friedrich.
Sep 15, 2018 | Friedrich Heating & Cooling
Remote codes for Friedrich split ac
You need a replacement remote for that unit. The codes are dedicated and not like television codes. You can't use a Universal Remote, especially as the functions of the split AC aren't on the remote.
Google
make model replacement remote
or contact the maker.
https://www.electronicadventure.us/friedrich.htm
Amazon com Replacement Friedrich Air Conditioner Remote Control...
Contact Us
https://www.remotes.com/friedrich-remote-controls-s/2027.htm
Jul 23, 2018 | Heating & Cooling
I working on a old Friedrich water source heat pump Model # V42 does anyone knows what size is it?
The friedrich name was taken off of units in the 80's when the climatemaster name was invented. My guess is 42000 btu or 3.5 tons rated capacity
Feb 05, 2015 | Friedrich Heating & Cooling
I'm looking for the accordian style panels for the friedrich qstar 06j10
Hello, here is a link to parts for your AC. http://www.searspartsdirect.com/partsdirect/part-model/Friedrich-Parts/Room-air-conditioner-Parts/Model-SQ06J10BA/3120/0904032/50024048/00002
Jun 20, 2011 | Friedrich QStar SQ06J10 Air Conditioner
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
NEED WIRING DIAGRAM FOR friedrich MODEL ES12L33A WINDOW UNIT
http://www.friedrich.com/downloads/Room_Air_Service_Manual_2008-2009_models.pdf
try this site. It has manuals. see page 54 as I believe it has your diagram you are looking for. Let me know if I can help you furher.
Oct 06, 2010 | Heating & Cooling
Heating & Cooling Logo
192 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Dennis Boxerman
Felizardo Erilla
Felizardo Erilla
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
