Question about Ford Garden
Have Ford 5000 tractor pto works sometimes.than quits or no power to pto .I have change pto clutch pack new / new oil / new hyd pump .
Posted by Gary Hovdebo on
Steven Waldon
    Top Expert:
  • Ford Master
  • 1,747 Answers
3 Related Answers
c17hydro
Greg Bernett
  • 2993 Answers
SOURCE: JOHN DEERE 5300 TRACTOR 3 POINT LIFT ARMS NOT
Yep....I have worked hydraulic systems for 17 years....you have air in the system and it needs to be bleed.
Posted on Mar 25, 2009
wilsodfarm
Donnie Wilson
  • 986 Answers
SOURCE: hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
Posted on Sep 02, 2009
collmann3
  • 18 Answers
SOURCE: when engaging PTO it takes
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Posted on Oct 16, 2010
I just bought a 1968 Ford 5000 tractor. Where are the pto clutch lever and the pto control located? Also, pto spins all the time. Any suggestions?
See the manual, free download
https://archive.org/details/tractors-19078764-Ford-Tractor-Models-2000-3000-4000-and-5000-Operators-Service-Manual/page/n15/mode/1up
Jan 13, 2021 • Ford Garden
TRACTOR ENGINE WORKS OKEY BUT NO MOTION
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem -
Best Manuals
Nov 11, 2017 • Ford Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 • Garden
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
Hydraulic problem
3helpful
2answers
My PTO will not engage without grinding but works great once engaged, Model is only shown on the engine as C10 with production code of 5F5B and serial A281771
when u engage u have to push in clutch and wait for spinning gears to stop the engage pto and let out clutch, excessive spinning of gears can be caused by low transmission grease also causing grinding
Garden Logo
Top Ford Garden Experts
Fahr Quad
NOEL
NOEL
Are you a Ford Garden Expert? Answer questions, earn points and help others
