Question about Golf
Hi my melex golf cart shudders at low speed no real noises goes well when at top speed what could the problem be
Posted by Gregory Parsons on
  • Gregory Parsons
    Gregory Parsons Jul 24, 2018
    Brushes not the problem any other suggestions what could b causing shuddering at low speed
  • Gregory Parsons
    Brushes not problem
Where can I get replacement springs/shock absorbers for Melex cart in Aus
If there are no dealers near you then mail order would be your only option.
Manufacturers are unlikely to commission special components if standard types are already available and so mostly as many vehicle and trailer parts as possible are bought in. Shock absorbers commonly feature in that list and so it is usually possible to source replacements from one of the many specialist suppliers servicing those who supply to the vehicle repair, modification and manufacturing trades.
Even when there is no application listed in the catalogue of such a specialist a replacement is usually possible using the detailed drawings and dimensions in many catalogues.
It is a similar situation with springs though the coverage is not as comprehensive. There are a number of specialists in addition who will repair or recondition existing springs or manufacture new springs to order.
A chat with a few of your local car or motorcycle repair shops should bring forth a few names to research and the Yellow Pages and google should manage the rest.
Jul 25, 2016 | Golf
Transmission shudders at low speeds
Torke converter needs to be replaced. Before you do that check the mounts.
Feb 10, 2016 | Cars & Trucks
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Why doesn't our Melex golf cart start after replacing batteries.
sounds like you have either a relay or computer that is bad, needs to be serviced
Nov 30, 2015 | Golf
48v club car 2004.speed issue
the module on the end of the motor should do the trick.
Nov 06, 2013 | Dual Pro 48V 18Ah Club Car Golf Cart...
2006 dodge ram 1500 low speed steering shudder
The 2006 Dodge Ram 1500 goes from 0-to-60-mph in just over 5 seconds with a top speed of 150 mph. Hope this helps!---------------------------------------------------------
Multi-Diag Access
Dec 04, 2012 | 2006 Dodge Ram 1500
Steering shudders when turning at low speeds
Please check you power steering fluid. It should be described in the owner's manual if you're not familiar.
Td
Nov 06, 2012 | 1999 Buick Regal
Wiring diagram , melex golf cart,model 212
I have a melex mod ha18cm and batteries are charge and its getting spark but not starting what should i do ?Also all the wires are connected .
Jul 05, 2011 | Car Audio & Video
Golf Logo
674 people viewed this question
Top Golf Experts
ray gallant
Kardoc
Bill Boyd
Are you a Golf Expert? Answer questions, earn points and help others
