SOURCE: My Bell & Howell cube slide projector has a
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
SOURCE: Can I buy a new Bell & Howell Slide Cube Projector?
No! They are no longer made due to the computer generation and slide presentations are usually made with laptops now. You should be able to find one good used one on eBay if interested find your model # of projector and look it up on ebay. They are usually in good condition but make sure lamp works on the one you are buying as these are expensive to replace. Rich
SOURCE: Need a manual for a Bell & Howell Model 173 16MM projector
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Testimonial: "Thanks. Sorry for the delay in recognizing the answer. Thanks again"
