Question about Krups Coffee Makers & Espresso Machines
KRUPS EA8250: Machine was going through cleaning cycle and stopped at the rinsing phase and displayed "Error Code 01". Any suggestions?
The Machine continues to display the error and makes a loud clicking noise that seems to come from the bottom area of the machine. The machine was taken a part and coffee grinder was not clogged.
Posted by AYalRo on
  • mulyadi dasril
    mulyadi dasril Jul 31, 2018
    Error Code 01.
    Check operation of distributor switches,
    Check distributor rotation (risk of drop in LV supply if distributor motor current too high).
    Check for wrong setting or position of motor in the distributor housing,
    Add the spacer above the switches.
Ross Keen
  • Krups Master
  • 1,364 Answers
Error code 01 accompanied by that noise points at the distributor being faulty. The distributor is the electronic tap that directs water to the ram to compress the grounds in the boiler and then redirects it to the brewing chamber to make the coffee, then to steam, then to rinse. It's the sort of item you just replace because it's quite a large job to change it anyway, not the sort of repair you want to be doing over and over trying not to spend money on the part.
Posted on Aug 02, 2018
5 Related Answers
Michael Anderson
  • 172 Answers
SOURCE: error message 5d on kenmore he2 fron load
Hi mankin1,
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck. Mike Anderson [email protected]
Posted on May 02, 2008
rafiqahmad
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
Roni Davey
  • 414 Answers
SOURCE: started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Posted on Jul 13, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
Anonymous
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Posted on Oct 24, 2010
Krups EA8250 Displaying "Filling of the machine necessary" with full water reserve and hopper.
I suggest that you use the commands to "close the machine" for transport and then re-start it as if it was new. I had to get rid of my EA8250 after only 2 years as mine stopping working as well. I tore it apart and saw a lot of wear for such as short time. My grinder also stopped. KRUPS says you cannot use Oily beans but only after you buy the machine.
Sep 20, 2017 | Krups Coffee Makers & Espresso Machines
Krups error code 01
I don't have a service manual so I can't say exactly what it means but I had the same error.
I fixed it by clearing out the pressure chamber where the grounds are compressed and the hot water is run through. There was a blockage that made the displacement lever (the little arm that moves spent grounds to the trash container) stuck and not fully able to move out of the path of the plunger.
To do this I recommend using a compressed air can and a long slender object (pipe cleaner is ideal) to scrape out residue in the chamber and around the moving parts.
Aug 24, 2014 | Krups EA8250 Fully Automatic Espresso -...
Krups ea 8250 error code 05
I have ea8250 krups machine . It gives me error code 05
Jul 29, 2014 | Krups Coffee Makers & Espresso Machines
My fontloader samsung wassingmachene p843 giv me and error code e3 4e and5e
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 22, 2012 | Washing Machines
Error code 01 on bosch dishwasher. what does this mean?
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
May 27, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Coffee Makers & Espresso Machines Logo
616 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
