SOURCE: Cannon Image Runner 3200
turn of the copier and hold down the 1 and 9 and turn the power back on. you shoule see a black screen with a little block in the upper corner. the blocks will fall to the bottom. when this is done cycle the power.it may take 30-60 minutes.
this is like a scandisk on a computer and will try to repair itself. If this does not work a service tech can try to format and reload sys software.
rep
SOURCE: cannon image runner c6800 error code E000001-0003
Its a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
SOURCE: E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
