Question about Sony Car Audio & Video
How to connect 1,200 amp Sony Colo to a Sony Colo CD car stereo
Posted by Carlos samoy on
micheal
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 23 Answers
Check here
https://freeonlineservicemanual.blogspot.com/2021/07/sound-audio-sound-instrument-manual.html?showComment=1625353857089&m=1#c1718629861852162499
Posted on Jul 04, 2021
2 Related Answers
kerguney
Kazim ERGUNEY
  • 577 Answers
SOURCE: Sony Amplifier, Sony CD Player,
The actual task of hooking up a home theater may take a little time, especially if you are doing a custom installation with lots of separate components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
Posted on Jun 22, 2011
Caleb Schlegel
SOURCE: sony car stereo, cd working but not radio
I'm an MESA certified installation tech for car audio, Pull your head unit out and make sure that your antenna cable is properly connected! If that's not it let me know!
Posted on Aug 26, 2012
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
2answers
Holden VR 1997 stereo removal instructions and installation
Here is a site which may help you:
http://www.usersmanualguide.com/sony/car_audio
thanks & have a nice day.
saumya.
I need a wiring diagram for the stereo on a 2002 oldsmobile bravada. i am installing an aftermarket stereo with an open ended harness because the quick harness is like $100! every diagram i have so far is...
most car comapnies use the same colo coordination, red, power, black ground, blue power ant, you could always contact Oldsmobile and acquire at least the pages which give the information you need
2helpful
IPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
1helpful
Car CD player plays but has no sound
Does your car have a premium sound system? Assuming that your cd deck is fine, try connecting your remote turn on wire from the sony to the corresponding wire on the car(if you bought a wiring harness, just match colors). Also some chryslers used a ground to turn on the amps.. a black wire with a female connector as well as a heavy ground ribbon cable... connect those 2 AND the ground to your stereo to enable the amplifiers.
2helpful
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
2answers
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
2answers
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
