Question about Frigidaire Kitchen Ranges
F22 code on Frigidaire electric range - Frigidaire Kitchen Ranges
Posted by Gerrianne Delaney on
5 Related Answers
D Clare
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
protek480
Craig Butler
  • 1730 Answers
SOURCE: F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 26, 2009
David S.
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
Philip
  • 949 Answers
SOURCE: my frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
Posted on May 17, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: Frigidaire FEF336BC Electric Kitchen Range F7 10
The "F7 10" fault code implies the left front potentiometer/left front burner switch is open and will need to be replaced. Here is that part to order.
Posted on Mar 31, 2013
Mar 31, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
Here are all of the error codes and solutions for Frigidaire ranges: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Frigidaire Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
My frigidaire electric range had a f1 code come
May 17, 2010 | Frigidaire FES367 Electric Kitchen Range
F1 fault code Frigidaire electric range
all solutions on the F1 show to replace the EOC control.
May 20, 2009 | Frigidaire FEF352 Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire Electric Smoothtop Range PLEFZ398EC
How do I replace the burner on my smooth top range?
Jan 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
My electtric frigidaire oven overheats
F 1 FAULT CODE INDICATES A FAILURE OF THE CONTROL.
REPLACE THE CONTROL(CLOCK).
Dec 19, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
176 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
