Question about Vulcan Heating & Cooling
Vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it.
Model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Posted by chris irtem on
5 Related Answers
Anonymous
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Natural Gas, convection oven won't heat.
If the gas valve is on(no continuity) then yeah that is it, keep in mind the ignitor could be weak. I didn't notice where you replaced the ignitor and you say it is working so that means the gas valve has continuity. You need 37 ohms on that ignitor or a total amp draw of at least 3.5 to open that valve.I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 14, 2010
Testimonial: "Thank you for the info, very helpful."
EMSRSERVICEG
Lawrence Walters
  • 426 Answers
SOURCE: Goodman Furnance model GMT070-4a The Burners
you need a service person to come out
Posted on Dec 09, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My furnace is blowing cold
Usually when that happens it is a high limit switch problem...
Check the back of the cover to see what the two blinks means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Posted on Feb 20, 2011
Tip
Parts list and drawings for S Type Jaguar
Useful parts list and drawings for s type 2000-2005 + helps find and identify for maintenance and problems <br /> Posted this in other areas please do the same if you feel it will help. <br /> <br /><a href="http://www.drivehq.com/web/jfenley/Parts_S-Types_2000-2005.pdf">http://www.drivehq.com/web/jfenley/Parts_S-Types_2000-2005.pdf</a>
on Jan 14, 2011 | 2000 Jaguar S-Type
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2017 | Vulcan Heating & Cooling
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Vulcan Bonaire gas ducted - gas flows and ignites, then fan makes sound like its struggling To get enough power b4 fuse in controller blows. fan spins freely. Any ideas what the problem could be?
have an electrician check the start/run capacitor for the motor
it may be faulty and the motor will not start properly and will blow the overload breaker
Sep 03, 2015 | Dryers
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
I have a GE freezer, model number FUF20DPARWH that blows a ground fault circuit breaker when it goes into the defrost cycle. The case is not "hot" when this occurs and it is plugged into a circuit th
Ralph, the only way to be sure of what is going on is to check the amp draw of the freezer when it is in defrost. If the amp draw is in range ( listed on model/serial tag ) you may have a GFI that is weak.. if unit does not defrost there will be an ice buildup on the lower half of the back wall... But with unit tripping GFI it probably is defrosting............ Ken Hawk
Jan 28, 2015 | GE Refrigerators
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Scanner error 6 give suggesion
hi, open scanner glass, remove cable from scanner, check scanner gears mechanism, if any prob on mech or mech parts is break ? change scanner mech with new one. if u r mech is ok, clean mech's gears and sensor. reinstall all parts properly.. now turn on and check printer again
Nov 21, 2013 | HP LaserJet M1005 Printer
Heating & Cooling Logo
57 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
