Question about Ricoh Office Equipment & Supplies
Ricoh MP 4000B backside of the copy very dirty especially lowest side
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
Transfer Belt Cleaning Blade need to be replaced.
Posted on Jul 23, 2018
5 Related Answers
SOURCE: Ricoh Aficio 450 back side is dirty?
when was transfer belt/blade replaced? +check for loose or broken conection to transfer ther will be yor problem more likely.
Posted on Mar 25, 2010
Anonymous
  • 1110 Answers
SOURCE: My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Posted on Jan 28, 2010
Anonymous
  • 24 Answers
SOURCE: ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Posted on Oct 29, 2008
Anonymous
  • 58 Answers
SOURCE: I have a Ricoh Aficio
Did you have this problem before you refilled the non-refillable cartridge? If not, you may have damaged the toner cartridge and like the above mentioned post you have a toner spill.
You could also have infected the machine with inferior toner. Ricoh machines are dual componet, meaning the developer and toner are matched to make consistant good quality copies.
Clean, clean and keep cleaning till you remove all of the toner from the unit and if that does not work, call an authorized dealer for professional repair. Was it worth saving $10 on refilling the cartridge?
Posted on Jul 28, 2008
Anonymous
  • 15 Answers
SOURCE: I need to copy and print a booklet from my Ricoh
Definitely, you need to download the RPCS driver.
Posted on Apr 16, 2010
How to fix a dirty copies of ricoh aficio mp c305spf
It is the photo drum which is causing this clean it or replace if it does not solve the problem.
Error 365 what the solution of it
SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
3helpful
2answers
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
4helpful
2answers
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
2answers
I have a Ricoh Aficio 2018 PhotoCopier. Recently it ran out of toner. I reinserted the old cartridge which I had re-filled with toner (ricoh). However the off-side (non-copy side) of the sheets are dirty -...
You probably have a toner spill which has gone under the transfer roller. Open the right side of the machine and you will see a dark colored roller on the inside of the open part. Stydy it very carefully and you will see how to remove the roller including it's holder. be carefull of the springs, they love to escape. also watch as to how the bushings and gears are assembled so you get them back on properly. Clean any toner out from underneath the roller, replace the assembly and run 10 copies of a white piece of paper. this roller runs on the backside of the paper and can cause your problem. Hope this works for you. Check your paper tray as well as toner can migrate down into them.
Dave T
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
