What model camera and memory card?
Examples of possible solutions to write protection:
https://howtorecover.me/remove-write-protection-microsd-memory-card
How to Remove Write Protection from Micro SD Memory Card
SOURCE: Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me.
Here is the first one
1.)go to MY COMPUTER
2.)right click on MMC drive
3.)click on eject.
4.)remove MMC form card reader
5.)again put it back
(if at once it didn't worked try again step{2,3,4}
second method is:
sometimes your USB port locks it try some other USB port & then put the MMC in memory card.
pls rate me
thank you
SOURCE: to remove write protection of my memory card for nokia 6630
we have dissame phone model... and i think i can help you ... get the memory card and a card reader and connect it to a computer then format .....in the computer you can format it
SOURCE: how i remove write protection in my mini sd memory card
Just go in these page there are a solution...
http://www.instructables.com/id/S27LXZRF7DWO18T/
SOURCE: how to remove write protection on a memory card
Removing the write protection depends on the source of the problem.
Broadly speaking, it can be any of the following scenarios
There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
== Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info:
Reason #1,
the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
