Question about Zoom Office Equipment & Supplies
What are x zoom and y zoom on ecelvan led96+ projector?
Posted by TOM SHANNON on
Clive
  • Zoom Master
  • 882 Answers
Width (X)
H
e
i
g
h
t
(Y)
of image.
Posted on Jul 22, 2018
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Mansfield holiday zoom model 501 8mm projector owners manual
Looking for a manual for Mansfield Holiday zoom 8 mm projector
Picture is too big for screen, projector wont zoom enought to fit screen
you will need to move your projector closer to the screen. you will need to zoom all the way out and physically move your projector closer to the screen and then adjust your focus.
6helpful
Jammed projector lens infocus lp770
get a wide bladed flathead and find the widest part of the **** between the focus ring and zoom. work the blade like you are trying to widen the the slot, do this all the way around till it pops back into place.
How do i make the picture to fit the screen on XR10X
You may have tried using the zoom ring located at the lens there are two rings one for focus and zoom. If this is not working you will need to either move the projector physically forward or backward from the screen until you can use the zoom accordingly.
Loogking for digital zoom procedure
move the projector back until the image fills the screen.
Can't get lens to zoom in and out
DIRECTLY BEHIND THE FOCUS DIAL IS A SERRATED COLLAR TO ADJUST ZOOM SETTING TURN LEFT AND/OR RIGHT THEN REFOCUS
Top Zoom Office Equipment & Supplies Experts
Ekse
Are you a Zoom Office Equipment and Supply Expert? Answer questions, earn points and help others
