Question about NEC Computers & Internet
My nec monitor keeps bringing up the screen resoltion box and it stays there for several minutes, blocking the show
NEC AccuSync LCD 93VX
5 Suggested Answers
Anonymous
  • 20 Answers
SOURCE: NEC 19'' LCD monitor power on but screen blank
If you can try it on another unit , If it still does not work, Then the most likely culprit is a bad power supply. If you know any thing about soldering replace the capacitors they are probably bad but being that these things are being built so cheap.It could also have a bad inverter. not repairable by average dude.If you open it be careful and do not attempt unless you feel comfortable with a solder Iron.Hope this can help you Good Luck. www.IrionsTVshop.com board re builders.
Posted on Feb 29, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
http://www.superwarehouse.com/NEC_AccuSync_120-BK_Black_21_CRT_Monitor/AS120-BK/ps/120193
Jerry G.
Posted on Apr 24, 2008
marcelbakker
Marcel Bakker
  • 174 Answers
SOURCE: NEC Accusync LCD92VM monitor
Hmmm, seen this one before, did you recently clean the screen with some kind of liquid cleaner/spray? I had to repair a monitor with same problems, some fluid had leaked onto the switch board....If not, any key's stuck or pressed in too hard?
Posted on Jun 09, 2008
Anonymous
SOURCE: NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Posted on Nov 18, 2008
Anonymous
  • 243 Answers
SOURCE: need manual for an NEC accusystem pv32
Your manual can be found at the link below
http://www.necdisplay.com/cms/documents/UserManuals/ManualASPV32_40_46_121007.pdf
Posted on Jan 09, 2010
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
I have a nec LCD2070nx Power light is on
Hi:
Your monitor has a problem on its inverter board. It is an electronic component failure, and often it cost's more to fix it than to buy a new LCD monitor .
Nov 23, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Help me please
Try this link, I am asumming you have the AccuSync LCD71VM monitor, I don't know what a n4 ibfgl is. But here is a link to nec that might help you...
http://www.necdisplay.com/SupportCenter/DriverFinder/
Download the file NEC LCD MONITOR Installer.
Hope this helped you..THK
Nov 24, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
NEC fs 5197 tv blank screen
I cannot assist but do you please have an owners manual for the FS 5197. I'm not sure if its against this sites "rules" but little fingers have tuned the menu's instructions into Arabic. Contact me directly at [email protected]. Thanks
Feb 10, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
Computers & Internet Logo
119 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
