Question about Emerson Audio Players & Recorders
I have an Emerson Extra Bass Extender CD/Radio player. Just recently my cd player is not working. Is there anything I can do to troubleshoot with?
Posted by Lisa Stacey on
5 Related Answers
Anonymous
  • 1665 Answers
SOURCE: CD Player / Radio Error Code
see a relative link
http://www.hondacarforum.com/honda-3/22348-2000-honda-civic-radio-error-code-problem.html
Posted on Jun 30, 2008
Anonymous
  • 289 Answers
SOURCE: the radio and cd player work but cannot display anything
hi..make sure that u have turned on the
display button the set.once u have turned
off the display button in your set ur display
doesn't appear.This display option will be
available in the set.
check it out.
thank u.. rate me..
Posted on Feb 05, 2009
josh markham
SOURCE: 2004 Chevy Trailblazer radio and CD player works, but no sound
if you have installed a new cd player in there then the propblem could be that your speaker wires and either touching each other or grounding them selfs out.. pull of the cd player and check to make sure all the speaker wires are covered properly and no bare wires are exposed.. if you still have a factory cd player in it then you will probably need to take it to a dealership to have it checked out..
Posted on Feb 23, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
Anonymous
  • 5 Answers
SOURCE: cd player and radio works no display
The led display legs are loose on the circuit board.
Posted on Aug 12, 2009
Toyota corolla 2004 radio and CD player stopped working same time while driving on the highway.
have you had any speakers or bass boosters installed in your car that werent in the vehicle before you purchased. Watch for wiring issues or possibly even battery voltage issues.
tip
A new User Manual EMERSON Clock Radio/CD Player (CKD9906)
Emerson Clock Radio/CD Player Model CKD9906
I noticed that the prior User Manual that I had uploaded is no longer showing up. I have uploaded a new one. I hope it will continue to help anyone who has lost their user manual.
2answers
Nothing on Radio stereo system works. The power comes on nothing plays. There is also CD jamed in the player. Where do I go from here? Emerson NR303TT serial number 61100051 CA
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Could you please explain the differences between the different equalizer settings as far as bass and treble
The bass setting can be set to either boost or reduce the bass (low frrequencies. At midpoint it is considered "flat", that is it neither boostts or reduces the low frequencies.
The treble acts the same idea BUT for the high frequencies.
Both these are essentially electronic filtering techniques to seperate the highs and lows.
1helpful
CD Player for 1998 Mercury Mystique
I just bought the same car recently and my son installed a cd/satellite/radio player into it with no problems. A high-end one that he took out of one of his cars. He's an audio freak that works in a high-performance car accessory shop. The only thing extra he had to install was some kind of wiring adapter to mate it with the existing factory radio harness. It only cost a few bucks. I think about $15.00. And there was no worries about wattage or anything else. Been using the player for about six-weeks now with no problems. If you remind me, I'll ask him about that wiring adapter....
Joe
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Emerson iTone iC200 Clock... Problem
I get no sound on either the radio or CD player. I need help.
Top Emerson Audio Players & Recorders Experts
 Francisco Mauricio...
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
