Question about Blenders
Where do I find the O RING 3.5 OD inches gasket for Living Solutions personal blender that I bought al Walgreens?
Posted by LUIS PEREZ on
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
[email protected]
Can I get a new gasket for a GNC on the go blender
Yes, you can order the replacement rubber gasket seal ring from nutri Bullet 600w or 900w which is the same size on ebay for $1.00.
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Gasket melting
Awesome...
Try AMAZON FOR THESE parts...
((amazon be cool... dogs drool & cats rule)).
4X Sealing Gasket Rubber Ring Replacement Seals For Ninja Juicer Blender...
Need a gasket for gnc on the go live well blender model # -HL-2574
Did you get any answers? I need a gasket for my HL-2571, Made by Home Life solutions. I've written them and have not heard back.
http://www.homelifesolutionsinc.com/contact/
6helpful
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
3helpful
5answers
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Blenders Logo
Top Blenders Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Blender Expert? Answer questions, earn points and help others
