Computers & Internet Logo
Question about LG Computers & Internet
I have LG TV 42LD550. When I try to play a movie from Flash drive using YSB it get the message "There is a problem with USB. I have used the format MacOS Extended (Journaled) as well as FAT.
Posted by Wayland Rogers on
  • LG Master
  • 6,611 Answers
To use a USB flash drive with the LG 42LD550, the drive must be formatted as a FAT32 or NTFS device. The drive should be 32GB or less. Not all USB devices will be recognized - this can be a driver issue. (I've had a few devices that didn't take a USB flash drive, if the drive required a driver to run under Windows 98.) If you use an external drive (portable or desktop), keep the drive capacity to 1 TB or less.
Next what files are on the drive? This TV will only recognize JPG images, HD DivX (.avi and .divx) movies and MP3 audio files. The not all codecs may be supported with these formats. Some people report losing the ability to play movies after certain firmware updates. If the drive has too many folders or files in a folder, it may not work. (This will happen sooner with the FAT32 format.) See page 96 of the user manual to see the file format limits on the USB port. The manual is available on the TV support page: https://www.lg.com/us/support-product/lg-42LD550 . The current link to the manual is http://gscs-b2c.lge.com/downloadFile?fileId=oqXZ71Wn8YXJ3OKzy9leAw .
I hope this helps.
Posted on Jul 19, 2018
5 Related Answers
Anonymous
SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
Posted on Feb 26, 2009
Anonymous
  • 72 Answers
SOURCE: Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Posted on Feb 26, 2010
Anonymous
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
Anonymous
  • 124 Answers
SOURCE: My lg lcd tv has a usb port but only recognises
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
Posted on Nov 04, 2010
fanaudi
fanaudi
  • 1381 Answers
SOURCE: l BOUGHT A 4 GIG
Hi , http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
Download this program . It should solve your issue .
Regards .
Posted on Jan 25, 2011
How can we play video from a USB device? Why can we not download more apps???
Shop for tv How can we play vide... on Google
WD TV® Media Player
$109.99
Staples
(165) Hauppauge Computer Ha...
$84.99
Dell
(400) C2G 29351 Micro USB to...
$21.23
Sears Audio?Technica ATR2USB 3.5...
$13.95
zZounds Diamond ATI TV Wonder H...
$39.92
B&H Photo-Vi...
(12) Search Results
    USB Flash Drive Movies on your Flat Screen TV - YouTube
    ? 4:10
    https://www.youtube.com/watch?v=ge4Wo9FQf8w
    Oct 5, 2014 - Uploaded by 21NorthMedia
    How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
    Watch a movie on your TV from a USB drive. - YouTube
    ? 2:40
    https://www.youtube.com/watch?v=jOhvbdVkPaM
    Nov 10, 2012 - Uploaded by DIYallday
    I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
From USB port unable to play the movies. The message unable to Protect, while opening movies from USB/ external Hard disk to play on TV Hisenese ER31607A
May be Speed of USB flash drive is equal or below Class 4.0. Try to check with Other higher speed USB Flash Drives. (Class 6 or Class 10 or HDMI)
HOW DO I USE THE USB PORT TO PLAY MOVIES
Some TV models have a USB port so that users could play videos and movies from USB on TV. You can try the following steps:
1. Connect your readable and writable USB drive to computer
2. Copy your movies to USB drive and then disconnect your USB drive from computer.
3. Connect the USB device to the Sony TV USB port. Turn on the connected USB device if necessary.
4. Press the HOME button on Sony remote controller to open the menu.
5. Enter the target USD drive.
6. Select the file you want to play back, and then press the play button to start playing movies on TV via USB drive.
It's quite easy to play movies from USB on smart TV devices.
2answers
TV is not showing the USB data
maybe you did not properly select the right application in your tv... example if you play movies go to movies menu and if thats music go to music menu and also for pictures go to picture menu......or the format of you data is not supported of you TV..
Lexar jump drive
Its the format of your flashdrive that is not compatable with the tv. Insert the flashdrive into the computer and reformat it into a format that your tv will accept. Google which formats your tv will work with and format the flash disk to that format.
USB port on LG DN898 Isn't playing movies from flash drive. TV screen is showing that the USB port is being used but no files are showing and nothing else is happening.
certain files are NOT register from DVD, you must read your instr.manual. The format is not support, you must convert your movies and know format from your DVD accoring in your instru.manual download the instr.manua. go to www.fitness.manualsonline.com or www.retrevo.com
God bless you
My 65 inch flat screen TV does not play a flash drive It reconizes the make and everything,But doesn't display or play a movie from the flash drive (Flash drive is from Lexar). And we bought the TV...
Hello nursedoreen,
It all depends on your TV. Not all tv's can play movies, and even the ones that can play movie files, it cannot play every type of format. Try changing your file format. Try avi, mkv, mp4 and so on. I hope this helps, give me a feedback if it doesn't. good luck.
- Joe.
2helpful
How to use usb?
you can play video or mp3 in usb input in your LCD TV , using usb flash drive
be sure the video you put in your flash drive is in AVI or mpeg format.
1helpful
I can not play the video on my lg tv from usb or rgb pc
What happens when you try to play it? Did you try accessing the USB drive through input and then select Movies? Note that cetain formats such as 3GP will not play. The video file needs to be in AVI or MPEG based formats for the tv to play it.
2answers
Thanks,
Siva Kaza
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
