SOURCE: Panasonic VB-43223
This phone you have is on a Panasonic DBS phone system. The phone system can be programmed to have any combinations of telephones ring under different circumstances. If you can swap phones around (with another known working phone) and the phone at that location still does not ring then it is definitely in the programming for that location not to ring. The phone system would have to be programmed. In that case you would need to get someone (phone system installation company) familiar with the system you have to re-program it. A phone system Programming manual would be required (not a user guide).
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
SOURCE: number of rings on Panasonic phone
Press the menu button and scroll to "ringer setting" and set to what you want. If that does not work scroll to "initial setting" and that lets you change the number of rings you want it on. When you set it to the number then hit save to save it and it will give you more rings. The second one "initial setting" is what I used.
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
SOURCE: my iphone won't ring with incoming calls. I have
The only thing i would check is the switch on the side. Make sure its not sticking, or accidentally switched it... If its messed up, im sure Apple would replace yours! :)
