Question about Blaupunkt Televison & Video
I have blaupunkt 43 "smart tv also a blaupunkt sound bar which cuts out sound when i change channels,is there anything i can do?
Posted by Eric Jones on
antoniorojas
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
This is automatic protection for a blast of sound bar
and try to connect it in other output if possible
or in settings audio low the volume to devices
Posted on Apr 27, 2019
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: sound
It's probably the audio amp Ic, which in that unit is a LA7612n...
Replace that and esr the caps locally and you should be good as new.. Otherwise the hissing will eventually be heard on all channels...
Bill
Posted on Dec 07, 2007
Steve LaHuis
  • 418 Answers
SOURCE: Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
Posted on Apr 14, 2010
Anonymous
  • 5 Answers
SOURCE: my tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Posted on Aug 22, 2010
Anonymous
SOURCE: No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Posted on Oct 11, 2010
SOURCE: I have a LG 55" smart TV and can not get the sound
get into your setting on your tv (menu) and click on the audio and make sure the speakers are in off position.
Posted on Dec 04, 2011
I have a blaupunkt 43" led tv that has stopped receiving a signal from the aerial. All worked fine until last week. I've tried another tv off the same cable and the channels appeared. I've tried a booster...
probably the problems started as the tuner board malfunction, replacing it should fix the problems.
Or, if you have the firmware of your TV, upgrade the firmware first
Oct 21, 2018 | Blaupunkt Televison & Video
My blaupunkt smart tv I switched it on sound but no picture red light flashing
Power board or more likely LED lamp failure, try the flashlight test
May 26, 2017 | Blaupunkt Televison & Video
Hi I have a THORN hd smart tv 55' turns on but then just black screen sound is fine can change the channel but can't see a thing tried unplugging it holding power button down for 60 sec
I have a 55inch thorn TV not a smart TV Tho n it keeps randomly turning off day and night n once it flicked from hdmi channel to normal TV channel, no set some or anything I'm worried a fault or boogidy, it's bout 5 or 6 years old n only been doing it the last week ??
Mar 31, 2017 | Televison & Video
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
Hi how do i connect a sound bar to my 43 in tv
Depending on the sound bar / TV configuration you can have various connection solutions.
The usual connections are HDMI, RCA and optic. Whichever route you take, consider what you want to achieve. For instance, I have a sound bar connected and use satellite as my TV source. Instead of connecting the sound bar to the TV, I opted to connect it directly to my satellite receiver as my receiver has this option. The reason I did this is so I can tune my satellite to a music station and play music through the home without having the TV on. No point of running the TV is all I want is sound.
G'luck!
Jun 16, 2016 | Seiki Televison & Video
Apr 12, 2010 | Philips Televison & Video
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Televison & Video Logo
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
