Yesterday I received such a message File is corrupted and cannot be recovered when I tried to open my file in Adobe illustrator. Now that the file is clearly in my opinion corrupted, I want to ask you, has anyone encountered such a situation recently and how was the problem solved?? is not one sort of thing?!
Possible fixes shown by searching the internet using https://www.google.com
It would help to know what version of Adobe Illustrator you are using.
Example:
https://www.easeus.com/resource/recover-illustrator-file.html
How to Recover Illustrator File After Crash
SOURCE: Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here http://www.illustrator.recoverytoolbox.com/
Also you can read here about corrupted file recovery: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/513-adobe-illustrator-file-corruption
Step 1
Launch Adobe Illustrator. Click “File” and select "Open” from the context menu.
Step 2
Choose the file you want to recover in the file-navigation dialog. Highlight the file but do not open it.
Step 3
Press “Ctrl-Alt-Shift” on a Windows PC, or press the Command-Option-Shift” keys simultaneously on a Mac.
Step 4
Click “Open” while holding down the keys. A blank window will open. Close this window.
Step 5
Navigate to the directory containing your file with the work you want to recover. Open it and look for a copy of the original filename preceded by an underscore (“_”) character. This is your recovered file ready for editing.
or you can try to use illustrator recovery , find here -https://onlinefilerepair.com/en/illustra...
