I'm no expert on jet-skis or anything but it sounds like you may have a "water-pump" issue. In the water it bogs and cuts out..... but put a "flow" of water from a "hose" and it runs fine out the water, the flow of water surpasses the water-pump and allows flow to cool the engine. I would check water-pump before I would go too far with it. Hope this helps, Jesus loves you, John 3:16-17 (KJV)
SOURCE: 94 jeep wrangler overheating
Have the cooling system pressure tested. If it holds pressure, that's a good thing. If it doesn't hold pressure, you may have a leaking head gasket. What may be happening is the crack in the head gasket could be blowing hot air into the cooling system causing it to overheat.
SOURCE: 1999 jeep wrangler very little heat
YOUR RADIATOR HAS TRAPPED AIR IN IT AND NEEDS T BE "BURPED".
SOURCE: 2004 Honda Civic -Code P0122 Throttle Position Sensor Voltage Low
yes, this is the case of a failed throttle body, in which case it needs replaced, the car is getting too much fuel causing the high idle. this needs replaced asap. you could proably find a small independant honda shop that could do the work for less.
SOURCE: need to reset to run flat tyre warning light on
i have a bmw , 1 series, i have just put air in my tyres and there is now a warning light on the dashboard, have i over inflated my tyres?
SOURCE: 2004 cheverolet impala 3.4L engine
Sounds like you have an air;lock in your cooling system.Try placing a bleeder on the return hose to the heater core ........looks like a small tap
