Question about JVC Car Audio & Video
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Posted on Feb 01, 2009
SOURCE: Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Posted on Feb 08, 2009
SOURCE: sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 19, 2009
SOURCE: No sound from Subwoofers after hooking up amp??
you can **** yourself
Posted on Mar 09, 2009
May 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
Mar 13, 2010 | Alpine CDA-105Ri CD Players
Jul 26, 2009 | Kenwood KDC-135 CD Player
Jul 08, 2009 | JVC KD-G230 CD Player
Jun 03, 2009 | Kenwood KDC-MP428 CD Player
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Aug 16, 2008 | JVC Car Audio & Video
May 13, 2008 | Car Audio & Video
Jan 12, 2008 | JVC KD-S580 CD Player
50 people viewed this question
