Question about Logitech Audio Players & Recorders
LOGITECH Z906 NO CONTROL MODULE ALL I HAVE ARE THE SUB AND TWO SPEAKERS LEFT OF THE LOGITECH Z906. HOW WOULD I BE ABLE TO USE THEM WITH NO CONTROL MODULE
Posted by Henry Palacios on
Steve Pack
  • Logitech Master
  • 4,777 Answers
You don't
Posted on Jul 17, 2018
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at [email protected]?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Posted on Sep 02, 2009
SOURCE: The Logitech Z906 speaker system
This is a bit of a difficult solution to give you. You may not need to ground the speakers unless you're getting a hum from them. In this case, my best suggestion would be to purchase a good quality power strip or low end UPS which will filter the power and reduce/eliminate the hum.
Hope this helps!!
Posted on Jun 20, 2011
Anonymous
SOURCE: Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Posted on Jan 18, 2012
Anonymous
  • 22 Answers
SOURCE: Logitech Z906 Speaker System "Codes directv" issues
Since you have solid products from the leader in 3rd party accessories it should be a snap. Just go to www.logitech.com/home. You shouldn't have any trouble there. Just ask a CS there CS is outstanding.
Posted on Jun 10, 2012
ray_stanyon
Ray Stanyon
SOURCE: logitech z906 remote stopped working
I just bought a replacement as the old one didn't work - new one doesn't either ! Do I need to do something to get it to talk to the amp?
Posted on May 20, 2016
1helpful
2answers
Whats the universal remote code for logitech speakers z906
No remote code for universal exists, you must use the logitech remote
2answers
Logitech z906 remote stopped working
Sometimes the battery terminals become pitted and don't make good contact, get a Q-Tip and rubbing alcohol to make sure it is spotless. If there is no change! take it to a TV tech. to verify it is the remote, if yes he may be able to repair it.
The Logitech Z906 speaker system comes with a two prong outlet. What is the best way to electrically ground the Z906?
Hope this helps!!
My satellite speakers are no longer working, logitech do not issue replacement satellites. Do you know if their is a way to use alternative sattelites with the subwoofer?
the back of the sub has 2 rca connections for left and right speakers so all you have to do is either find satellites that use rca connections or find or make your own "clip-on" or detachable wire to rca connection.
Here's my problem: I have 5.1 logitech speakers. The plug where the yellow jack goes into the subwoofer seems to be broken. No sound coming from this speaker (rear left). The problem isn't in the cable...
2 possibilities, either the connection coming out of the sub has gotten disconnected on the inside of sub or that channel is bad on your amplifier in the sub. The only way to know for sure is to open the sub up and ck.
Logitech Z-560 Left Channel died
The fuse is inside. Remove the screws from the back, around the outside only. Pry it up and it will pop off. It is a bus fuse 4amp 250V. Disconnect the sub from everything. After I replaced the fuse I pluged it in. When I turned the switch on the fuse popped. At $50 an hour to repair I decided to replace the whole unit at a price for $80. Here is a link http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2507686&csid=ITD&body=MAIN
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
