Radio Communications Logo
Question about Radio Communications
How to pair a scala q2 with a scala q3
Posted by moira fortin on
4 Related Answers
Anonymous
  • 21 Answers
SOURCE: battery removal
Okay here's how to remove the battery:
1.Lay phone back up on a flat surface
2.You will see a tiny little tab that you can with your nail pull back that is like a safety release.
3.Then with your other hand grasp the two sides of the back and pull it off
Ta dah you did it
Posted on Nov 14, 2007
Anonymous
SOURCE: garmin zumo 550 bluetooth pairnig problem
The Bluetooht of my zumo 550 can not be switcht on, what ever i do.
The first time it works perfect and it was pairing with my phone afther that it stopt working
Posted on Jul 08, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: I have a sportsart 6300 that keeps blowing up Q2
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Posted on May 13, 2010
Anonymous
SOURCE: the scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
Posted on Dec 01, 2012
Cardo q2 pairing
hard rest. remove battery and clear any settings from the mobile phone. is discovery ON?
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
The scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
1helpful
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
I have a sportsart 6300 that keeps blowing up Q2 and Q3
2answers
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
