SOURCE: Replacing the rear rotors on a 2003 E320
So this is what it takes to replace rear brake rotors on a 2003 Mercedes E320;
1) open the bonnet (hood) of the car and loosen/remove the cap off of the brake fluid resevior.
2) remove outer spring clamp from brake assembly (it clips in to the iner edge of the holes of the caliper).
3)using a 7 MM allen wrench, remove the brake caliper.
4) using 18 MM box wrench, remove the caliper housing assembly off of the wheel hub.
5) using a star wrench, unscrew the rotor locking screw from the rotor
6) squirt some liquid wrench on the rotor hub and knock the rotor with a hammer to work the liquid wrench in.
7) using the same hammer, knock the rotor off the hub.
8) using a metal file, lightly file old residue off of the hub and place the new rotor on the hub.
9) set the hub by screwing in the lug nuts and then screw in the hub locking screw using the star wrench, then remove the lug nuts.
10) reinstall the caliper housing assembly onto the wheel hub using the 18 MM box wrench.
11) push back the brake claiper piston to its home position and install the inner brake pad (the one with the snap clips)
12) insert the outer brake pad in the claper housing assembly.
13) slide on the caliper housing with the inner brake pad in place (over the outer brake pad) and screw in the caliper screw rods using the 7 MM allen wrench
14) on the right wheel brakes, DO NOT FORGET to slide in the brake sensor (the one with the black connector) and connect it to the connector on the caliper housing.
15) be sure to reinsert the spring clamp onto the outer brake assembly to set the assembly squarely onto the wheel (there should be no wiggle in the brake assembly after the spring clamps are installed).
16) finally mount the wheels.
17) you can bleed the brakes at this point to release any trapped air (which is unlikely) but be sure to pump the brakes after starting the car BUT BEFORE MOVING IT to re-preassurize the brake system before driving the car.
17) ONE WEEK LATER - recheck brake assembly to ensure all is okay and brake fluid.
This proposed solution is for a 2003 Mercedes Benz E320 and NOT a 2005 model as stated by the limited option selection provided by FIXYA.com when initially describing the problem.
SOURCE: 2004 toyota rav4 rear bumper assembly guide
there are two bolts to the center and two around the corner on at the edge up high and one at the bottom of the bumper/ Please rate my response thank you very much
SOURCE: Replacing front wheel hub assembly on 2006
Caliper mount bolts are 74 ft/lbs
Driveshaft axle nut is 177 ft/lbs
Hub and bearing mounting bolts are 133 ft/lbs
Testimonial: "The info on the torgue specs was very helpful. I couldn't find it anywhere. Thanks a bunch!"
SOURCE: I would like to replace the headlight assembly of
There is a little aluminum stick in the assembly holding it in. On the top of the headlight twist the stick and remove it. It will look like a tent stake. Remove this stick and then the head light assembly will almost fall out.
SOURCE: Replace front hub assembly....
Replacing the front wheel bearing/hubs can be a big job for the inexperianced. Briefly...
Remove tire/wheel
Remove brake caliper assembly, do not remove brake line.
Remove caliper bracket.
Remove brake rotor.
Unplug ABS sensor.
Remove the large axle nut.
Press axle out of bearing (may need special tool)
Remove the 3 bearing bolts and remove bearing.
