Question about Adidas Watches
Adidas watch ADP3256, can't set it. The watch reset itself and on the screen is notification "turn bezel" and when I turn it nothing hepens, can't see the time, steps, log or anything else.
Posted by Tina Glas on
5 Related Answers
rotagen
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Posted on Jul 30, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do you set an Adidas Watch (Women's ADH6051)
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please
Posted on Mar 10, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I dont know how to change the date/time for my adidas watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please .
Posted on Mar 15, 2010
Anonymous
SOURCE: How do I set the
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px} p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica; min-height: 16.0px} span.s1 {letter-spacing: 0.0px} span.s2 {font: 12.0px Helvetica; letter-spacing: 0.0px} span.s3 {font: 13.0px Arial; letter-spacing: 0.0px}
I have the Adidas ADH4018 and I assume the controls are the same, unfortunately, Adidas has absolutely no manual online for this watch. I've figured out how to do most of the functions of this watch.
NOTE: For greater setting accuracy, I recommend using a stylus-like object or the retracted tip of a retractable pen (as to not write on your watch) to click the number keys when setting the time and date for the first time.
Set the Time:
To set the time go into time mode by pressing the lower silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes, press the number 9 to start the seconds over at 00. Press the multiplication key (x) to change from 12 hour to 24 hour time modes. When finished press the time mode key.
Set the Date:
To set the date go to time mode by pressing the lower silver button on the left side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 4 to change the month number. Press the number 5 to change the day of the month. Press the number 6 to change the day of the week (indicated by a small dot above the days of the week abbreviations at the bottom of the digital display. When finished, press the time mode key.
Set the Alarm:
To set the alarm time, enter alarm mode by pressing the upper silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes. When finished press the time mode key.
Turn the Alarm On or Off:
To turn the alarm on or off, first enter alarm mode by pressing the upper silver button on the right side of the watch face. Then press the divide key (÷) to change from on to off or off to on. When the alarm is ON an indicator icon will appear in the upper right of the display in time, date, or alarm mode. When alarm is OFF there will be no indicator icon displayed.
To Use the Calculator Function:
Enter Calculator mode by pressing the Clear All (AC) key on the keypad when in time mode. Use the number keys and function keys to complete calculations. To return to time mode simply press the time mode key.
As of yet I have not discovered how to turn off the annoying beep when you press any button.
Posted on Oct 27, 2010
fezanddjango
SOURCE: Just bought an Adidas Seoul Watch ADH2044 and
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Posted on Jul 11, 2011
I just bought the adidas ADP6000 watch from argos and the manual is no help at all and i cannot work out how to change the time and date even though i have researched online :(
Okay so I had the same problem as all you guys, fiddled around with the buttons for a couple seconds (literally) and worked it out
The following instructions are for tADP6000:
1- press and hold 'SET/LIGHT' button
2- it should say 'LIGHT' and 'OFF' flashing, now press 'MODE' until you reach the screen you desire, then use the 'START/STOP' and 'LAP/RESET' to change between 12hr/24hr; time; date etc etc. hope this helps
Jun 13, 2011 | Adidas Digi III Watch
I have done everything possible to set my Adidas Seoul watch but nothing is working. I have read the manual. When I press the D button, it only brings turns on and off the music.
Feb 01, 2011 | Adidas ADH1572 Watch
I need help setting the time and date on my Adidas Plastic Peachtree watch ADH4012 900912 can someone please help!!!!
A- Top right B- Bottom right C- Bottom left D- Top left Press C button until you get to the time screen. When the time screen appears press and hold down the D button. The light on screen appears, Press C and the chime on screen appears, Press C again and you can start setting the time using the A and B button. When finished press the D button.
Jul 16, 2010 | Adidas PEACHTREE watch
Mar 10, 2010 | Adidas Digi III Watch
How to set the time on an addidas wooster watch
Put "adidas watches" into your search engine and select the Adidas.com site.
On the screen you will see a menu, select "instructions" and look for your watch in the list of illustrations that are there.
Jan 13, 2010 | Adidas Wooster ADH1768 Watch
How do u set the time on a adidas peachtree watch
Put "adidas watches" into your search engine and select the adidas site.
On the left of the screen is a menu , select "instruction manuals" and instructions appear.
Jan 06, 2010 | Adidas PEACHTREE watch
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Watches Logo
134 people viewed this question
Top Adidas Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you an Adidas Watch Expert? Answer questions, earn points and help others
