Question about Microsoft Xbox 360 Console
3red flashing lights
When i turn my 360 on ,i hear a clicking noise then comes the red ring
Posted by tafari on
Anonymous
Hey Tamari, it's an overheating issue that is common in xbox 360 models made within a certain date range. I had the same problem a few months ago.
All you have to do is contact Microsoft tech support and provide them with your serial number. They'll ask you a couple of questions and then they'll get you to ship them the 360. (They pay for shipping).
They'll try to repair it, but if your lucky like me, you might get a new xbox 360 and one month of xbox live for free.
Hope this helps. Worked for me, should work for you.
- klassiq
Posted on Nov 25, 2007
Anonymous
Hey Tafari, It's an overheating issue that is common in xbox 360 models made between a certain date range. I had the same problem a few months ago.
All you gotta do is contact Microsoft tech support and provide them with your serial number. They'll ask you a couple of questions and then they'll get you to ship them the 360. (They pay for shipping)
They'll try to repair it, but if your lucky like me, you might get a new xbox 360 with 1 month of xbox live for free.
- klassiq
My Xbox 360 won't turn on at all and I have checked all connections. How do I get it to turn back on? There is no three red ring thing, it simply will not turn on.
u try switch on in hdmi mode or else u upgrade it and try to turn on..if nothing work for u ..u can also check with this site click hear
Dec 01, 2010 | Microsoft Xbox 360 Console
My xbox 360 has the red ring
this red ring problem is a very common one in xbox u can see the setting to solve this or u may visit this site to solve the problem. click hear
Nov 08, 2010 | Microsoft Video Game Consoles & Games
I have three rings when i turn it on. then when i play the game it will freeze most of the time. when it freezes i know its not the game because the screen will mess up and u will hear funny noises. and u...
If you have the 3 red lights showing it means that the heat build up has got too bad on the GPU and the CPU and you will need to get it fixed, you can send it in for repair or fix it yourself using a good repair guide.
Oct 20, 2010 | Microsoft Xbox 360 Console
Xbox360 has sound but no picture
If you look up further on this thread i HAD the same problem. This is how i fixed it. I needed it to red ring so i could send it back in to get replaced since my 1 year warranty was up. But i fixed it instead. So here is how you do it. First i took off my hard drive on the 360. Then i plugged it to the TV not with HDTV (use the red, yellow and white make sure it is on TV not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i plugged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wrapped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 minutes depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room. if this don't help you now you have a red ringed 360 and you can send it in to get repaired since there is a 3 year warranty for red ringed 360's.
Good Luck!!
Thanks!!
Aug 14, 2010 | Microsoft Xbox 360 Console
Screen is all different colors and lines
wrap it in 2 towels 4 ten minets n the pictur should come up worked with mine but the day later got red ring of death
Jun 10, 2010 | Microsoft Xbox 360 Console
Sound of game playing but no picture
Do the following at your own risk
First take off hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then plug it into the wall with the 360 laying down not up and down and turn it on. (no picture but sound) with the 360 on take 1 towel folded it long ways and wrap it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. . if this don'ts help you now you have a red ringed 360 and you can send it in to get repaired since there is a 3 year warrenty for red ringed 360's.
hope it helps-but remember its risky
Aug 10, 2009 | Microsoft Xbox 360 Console
Xbox 360
check your av cable. if its set to hdtv it wont show up on your screen
Jun 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
XBOX 360
check connections.
e-mail me at [email protected]
May 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
99 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
