Question about Radio Communications
SOURCE: Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Posted on Dec 08, 2008
SOURCE: Need help with Case Logic bluetooth ear piece model BTH-10
The generic PIN for that bluetooth is : 1234
Good luck
Posted on Dec 12, 2008
SOURCE: Ear hook and ear bud replacements for Motorola H375
Here a site for replacements.
MOTOROLA H500 REPLACEMENT EAR HOOK
$4.50http://www.worldwidecelldeals.com/store/
Posted on Apr 02, 2009
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
