Question about Radio Communications
SOURCE: my chrysler pacifica dvd player
Had the same problem, took my Pacifica to the dealer where they diagnosed an internal mechanical malfuntion. They said the only way to fix it is to rebuild the unit. Luckily I bought the 7 year 100 thousand mile warranty and didn't have to pay the estimated $700.00 parts and labor charge. It is fixed and works just fine.
Posted on Jan 12, 2009
SOURCE: The Incredible Holiday Light Show will not turn
I was told to put a paper clip or key across both prongs that you plug into the wall. This grounds it out. Then you resync the remote with the black. It worked for me.
Posted on Dec 09, 2009
SOURCE: my samsung eternity from at&t
have you tried taking out the battery and turning it off for about 2 minutes then put it back in and turn it on it should work
Posted on Dec 21, 2009
SOURCE: i am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Posted on Jun 30, 2010
SOURCE: DRYER MODEL AEQ7000ES1 keeps getting
E68 means a button is stuck on the control board, you can lightly press all buttons and see if that clears the problem. Next slam the door shut as it may be the sensor door latch, then unplug the dryer as it maybe lint built up on the lint trap: remove your lint filter.remove the waffled plastic that covers the lint filter slot. , its inside the dryer, and there's two screws holding it in. Be careful, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is a sensor. Don't drop the screws into the lint filter slot. you might find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint and if you have an attachment for you vacuum you may want to use it just be careful and plug back in , and reinstall. Might want to check the vent tube since we are cleaning as it may be restricted. unplug dryer and the last thing is to take the back off and see if the control board itself is damaged or dirty, if it is dusty/dirty with a brush lightly brush it off. If none of the above worked then I would call the company at 1-800- 444-4944. Good Luck Tim
Posted on Nov 08, 2010
