Question about Roper RAB2121KW Top Load Washer
Washer takes forever to fill
Hi - We are having problems with the cold water on our washer. The washer takes forever to fill if I am running the cold water cycle only. The hot water runs in fine. The hose connection looks clear and we have cleaned the filter repeatedly. Help
Posted by JulsH on
  • Anonymous Mar 10, 2008
    ** cold water
Anonymous
  • 213 Answers
Sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Posted on Nov 25, 2007
Cold water runs slow
Turn the cold water off and remove the hose at the machine. You will find a screen located there and you will need to clean it out.
Apr 27, 2012 | Washing Machines
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Slow to fill the washer
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 10, 2010 | Crosley CAWC529JQ Top Load Washer
When washer fills with cold water there is very little pressure and it takes forever to fill.
Turn off the cold water valve.
Remove the cold water hose from the washer. Clean out the filter screen on the water valve. Replace the hose and run the washer.
Apr 21, 2009 | Washing Machines
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
You said you checked the screen at the faucet end, did you check the one at the washer connection? Most washing machines have a wire mesh screen which sits inside the plastic connector that the hose connects to. You will have to use a small pointed object (like an ice pick) to remove the screen and clean it. Be careful not to damage it, I have ruined them on more than one occasion and had to replace it with a new one. If that is not the problem, there is likely a problem with the valve that is controlled by the hot/cold knob. I am not familiar with your washer brand, but mine required quite a bit of disassembly to get to the valve and switch, and in my opinion is a job better left to the local repair man.
Jun 04, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Roper RAB2121KW Top Load Washer Logo
138 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
