Question about Home Fencing
How I can fix energy bills of my home?
I am tired to paying huge electricity bills. can someone tell me how can I reduce them to minimum.
Posted by Cecilia on
  • esspeajay Sep 28, 2018
    In many cases energy is lost due to inadequate insulation, older style windows, especially single pane windows. and HVAC ductwork that is poorly insulated or leaking. If your attic or basement are unusally cool in the summer or exceptionally warm in winter you might be losing energy through faulty ductwork. or missing or inadequate insulation.
    There are many ways to reduce your energy bills. Many are as simple as wraping your water heater with insulation, caulking windows and doors, or turning you HVAC up or down as little as 1 degree in either direction depending on the season.
    There are many "smart" devices which can reduce energy consumption such as smart thermostats and smart lighting. Water heater timers work well as do circulating pumps designed to provide more instant hot water for showers etc. meaning less time running water waiting for it to reach a comfortable temperature.
    I suggest the very first place to begin is an energy audit. Most power companies offer a professional home energy audit free of charge. They will identify the deficiencies. Suggest methods of correction, and in many cases offer monetary incentives such as rebates, tax incentives and frequently, assistance programs to provide upgrades at little or no cost to the homeowner.
Vernon Taylor
  • 7,436 Answers
Ensure your electricity is being accurately metered and ensure you are on the most suitable tariff from the cheapest supplier in your area.
Ensure no one else is using your electricity - if you have near neighbours it is possible by a mistake or dishonesty for you to be supplying or partly supplying another home.
Leave the main isolator on but switch everything else in the house off or unplugged from the power outlets and your electricity meter should not be recording any consumption.
If that test is ok then all the power being consumed is being consumed by you and the way to save money is to consume less and that means using low energy lighting or leds and switching stuff off that isn't being used - that means switching off and not leaving stuff on standby like it is a new religion, keeping the thermostat low and wearing extra layers of clothing in winter and using fans and/or a cooler in summer instead of aircon.
Ensure your home is adequately insulated and then some. Draught-proofing is a must apart from essential ventilation and in winter secondary double-glazing is a big help along with heavy curtains. Reflective film on the windows can help keep rooms cooler in summer and warmer in winter.
Posted on Sep 30, 2018
Nancy Winfrey
    Sergeant:
  • 120 Answers
High energy bills is a very common problem. Every home owner or tenant wish to save energy to lower energy home energy bills. There are different ways to lower your home energy bills. I am going to share a blog post which will guide you to do it properly.
Posted on Jul 16, 2018
pawnpower
    Master:
  • 851 Answers
Stop using energy. turn off all the lights, shut off water heater, and turn off air conditioner.
Posted on Oct 19, 2018
1 Related Answer
Anonymous
  • 20 Answers
SOURCE: How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Posted on Mar 31, 2009
Should people invest renewable energy?
While it's fairly easy to fit solar panels on your roof to generate electricity - and save money - investing in funds that hold the wind and solar firms offers more of a challenge.
It sounds like the perfect investment. Equip your house with solar panels and look forward to dramatically reduced utility bills and the potential to earn a handsome return by selling any excess energy to the electricity grid.
Thousands of people across the country have already embraced this idea since the government introduced the Feed-in Tariffs (FIT) Scheme in April 2010 to encourage the uptake of small-scale renewable and low-carbon technologies.
Greg Shreeve, the insight manager at the Energy Saving Trust, believes getting solar panels installed is a no- brainer for many people. The potential benefits to be enjoyed, he argues, more than makeup for the upfront costs.
"The technology pays for itself within 11 years and will go on generating electricity for your home," he says. "It's a great way to actually start making money when energy prices are rising. It's free electricity and low-carbon technology, so a winner all round."
Apr 02, 2017 | Computers & Internet
What does energy saver do ?
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
Nov 06, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
Home Fencing Logo
492 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
