Computers & Internet Logo
P
Pat Brantley Posted on Jul 16, 2018
TomTom VIAA 1500 TM.
How do I delete home address and add new one?
3 Related Answers
A
Anonymous
  • Posted on Mar 01, 2008
SOURCE: deleting wrong home address
Tap on the screen, go to "Change Preferences",then browse to "Change Home Location" and set the correct location.
Angel Dr
  • 121 Answers
  • Posted on May 04, 2009
SOURCE: How do we delete an address in my Tomtom GPS?
tap change preferneces tap manage favorites tap delete
Anonymous
  • Posted on May 31, 2009
SOURCE: How do I remove old address from my Tomtom Xl
please tell me how to delete address from the tomtom system
2helpful
2answers
Tomtom go 2535 tm not connect to windows xp
uses a online server by tomtom, you cannot access the data like the older tomtom home versions. use 'my drive coonect' to update
Tomtom520 had a new battery fitted now can only get 3 parts of zip code
The folder 'ZIP' has been deleted from your tomtom unit.
If you have a back up simply copy and paste it back, if you have made a back up using tomtom home look in, my documents/tomtom/home/backup. This is the default location for tomtom home. If you cant find it anywhere, give me your email address and i'll send it to you
1helpful
I have a new TomTom Go 2535 that is reading No Maps Found! I have tried a hard reset with no luck. The TomTom seems frozen. Can you help me...
Usually, you'll want to connect a new TomTom GPS to your computer, and (using TomTom HOME), register the device and get the latest maps (downloaded and) installed on your GPS.
Then, you'll have maps on your GPS.
2answers
It shows a 'X' mark
the other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
1helpful
Can't delete home address
Scroll through your menu and somewhere there is an option to change home location. Just put in the correct one and your incorrect one will delete.
4helpful
2answers
3helpful
2helpful
My 720 frozen
• The device hangs in the start screen (splash screen )
21helpful
7answers
Attempting to download tomtom.com/home. Did not load automatically, so did as suggested and searched for tomtom.com/home. Google asks if I want tomtom.mobile, etc. Do not have broadband. What do you...
have you tried setting your home address on the tomtom itself? I was having the same problem until I did that and then it downloaded. But it wont download by itself. You have to go into your "my computer" file and find the tomtom device and select installtomtomhome
Deleting wrong home address
Top Tomtom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
