Question about Vision Televison & Video
Is the a remote control for the 13" diamond vision tv/DVD model number DVT1461? If so how do I get one?
Posted by Marlyn... on
5 Related Answers
rozmerle
SOURCE: code for remote / Diamond Vision DVD Player model: DVD807-04
I found the code! It is 0736. The company is now called AudioLogic.
Posted on Dec 30, 2007
Anonymous
  • 518 Answers
SOURCE: remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Posted on Mar 05, 2008
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Posted on Aug 09, 2008
Anonymous
SOURCE: Lost the manual for programing codes
i need to know how to program the remote
Posted on Oct 25, 2008
wing_guy_196
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
We have a Diamond Vision TV/DVD and the remote does not work. Is there a contact email or 1-800 number I can call to order a replacement one?
Diamond Vision is actually manufactured by Mitsubishi, so you can use this website to figure out the remote model # using your TV's model #. Then you can call the 1800 number listed on the top of the page to order it :)
Jul 18, 2011 | Televison & Video
Diamond Vision TV Code
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Diamond Vision TV/DVD combos in the One For All URC-3021 Code List.
But don't give up; many manufacturer's re-use others' control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code Entry
One For All URC-3021 Reassign Key
May 23, 2010 | One For All URC-3021 Remote Control
Sanyo tv,RCA universal remote,Diamond Vision player--compatible?
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Jan 12, 2009 | RCA 3-Device Universal Remote with...
I need to know if there is codes for a 5 disc changer dvd player that is Durabrand model
Oct 08, 2008 | RCA RCR311B Remote Control
DVDV809-04
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
Sep 02, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
I have a remote diamond vision vcr/dvd
if yours plays DVD's I will take it off your hands.
The one I bought from Walmart has never played one disc. Always says wrong disk. Factory set for region 1 and I live and bought it in region 2.
Jul 13, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Jul 06, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Diamond Vision TV/Remote
SOLUTION: I had the same problem with a Diamondvision DTV3913. After trying many universal remote controls, I found one that worked. The RCA universal remote CRCR3273 / CRCR3373 (also referred to as RCR3273 / RCR3373) was the answer. It has 3 codes (1232, 1233,1234) for DiamondVision TVs and the first one worked. It gives me all the control I needed including the hard to get ones like input selection, main setup menu etc. It also has codes for DiamondVision DVD players and VCRs. I see it at BestBuy for $8.
Jan 10, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Tv/dvd
Try ordrer the original remote contrl by Tv's manufactory. Aleixo
Sep 04, 2007 | Toshiba MD20FM1 20 in. TV/DVD Combo
Televison & Video Logo
74 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
