Question about Frigidaire Ovens
Frigidaire Oven model number LFEF3011LBD. Top and bottom elements not working. Replaced elements, Checked volts and Ohms and everything checks good from power supply to control board and no freyed or burnt wires. I cannot find a reason for this condition.
Posted by Rick Barber on
Clive
  • 882 Answers
Have you checked fuses?
Otherwise the control switch or thermostat may have failed.
Posted on Jul 15, 2018
  • Rick Barber Jul 15, 2018
    The Oven Schamatic does not show any of these components. Please let me know where they may be located.
  • Clive
    Clive Jul 16, 2018
    https://www.manualslib.com/manual/462434...
    and its service manual are the only sources I could find for this model.
    Looking through the manual I see that it also has EOC so this could also be faulty / corrupt.
    My first answer above was just a generic for all standard ovens.
5 Related Answers
D Clare
  • 116 Answers
SOURCE: frigidaire oven
Hey dardem90
Is that the only thing that it does not do? Does the broiler work? Do you hear any clicking sound when you try the bake (bottom element) ? If the boiler work and you hear the clicking when you try the bake then one of the contacts on the relay may be weld stuck. If you know how to you could change the relay otherwise you have to replace the clock on the stove - Try repairclinic.com
Regards
Posted on Sep 23, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
Anonymous
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Model YRBS305PDQ3... After self-cleaning lost
Based on the important nugget of info you provided "after self cleaning" I`d suspect a tripped hi-limit thermostat. It should be located at the back wall of the oven. It will be a small disc shaped component with 2 wires going to it. Most of them on whirlpool are the non-reset-able style which means you`ll have to replace it. ( by memory I think it`s # 9759243 and around $25-$30 )
You can check it with your meter as well, ( **please unplug the unit or shut off the breaker when performing any of these suggestion`s** ) just open or closed is all you need to know, the ohm value won`t matter for this device. I don`t like to assume, but again based on your post I feel safe to assume here, you know if it`s in the open position it`s opening the circuit or in other word`s "tripped" from hi-temp. hence, not allowing power to the element`s.
Hope this answer`s your question. If not let me know and I`ll try to assist you further. If so, please rate the solution accordingly.
Thank`s for coming to "fixya" and good luck.
macmarkus :)
Posted on Mar 19, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: My name is Val, and
Here is a diagram for your oven. Look at 21 on the diagram, this is a resistor (fuse) that may have blown on your oven.
Posted on Jan 21, 2011
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Why the oven does not work.
You may have a bad door switch not allowing the proper 220 volts to go through.
Jan 23, 2012 | Ovens
This is a repost per instructions from FixYa I would prefer to hear from heatman101 on this please.We just reinstalled a used GE JTP13GV wall oven that was working when it was removed. Everything...
So you have voltage at the incoming side of both elements - good. If you have tested the element with an ohm meter across both terminals with both wires disconnected and have a reading of 1067 ohms you have a porblem. On a 240 volt system as an example with a 2000 watt element the resistance of the element should be 29 ohms. 1067 ohms means there a very slight circuit but when power is applied it simply will not work.
Just try that test again with the wires off the elements. It should not be over 100 ohms. If it is the elements are faulty.
Also with a voltmeter test across the terminals of the elements with wiring connected and the oven elements turned on. If you have full supply voltage across the terminals it definetely means that the elements are faulty as the full supply voltage represents a good active and neutral path.
If you test again and the continuity/resistance of the elements is good then the power isn't returning to the main neutral terminal which means that you have a faulty neutral. Sometimes the thermal cut-off switch has the neutral wired through it. With the whole of the system turned on and the wiring accessible you can use the voltmeter to trace the voltage path from the oven switch, through the elements and back to the neutral.
Feb 09, 2011 | Ovens
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Double oven... top works great, bottom has power but will not heat. No codes showing. Have had ohm meter on it and all is functional to elements. GE Profile model # JKP56BOA1BB, older model... maybe 1999.
Do you have 220 volts to the element. If you do then you have a bad element. If you don't then it is usually your erc (electronic range control) or your oven sensor. You need to test your oven sensor for the proper ohms, (should be on your wiring schematic), replace the sensor if you don't have the right ohms rating. You can also compare the upper oven sensor rating with the lower oven sensor rating. If your sensor is good then you need to check if your erc is sending 220 volts down to the lower oven element. Again you need to look at your wiring schematic(usually found in a sleeve behind the oven control panel), to determine which terminals to test. As always you need to be sure that you know what you are doing when you are working with live voltage. If you don't know how to work on live electical products you need to call a technician. It can be very dangerous. Good Luck, Appliance Specialists
Dec 14, 2009 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Ovens Logo
219 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
