Question about Sylvania Televison & Video
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
Posted on Jul 15, 2018
SOURCE: sylvania 27 in. tv/vcr/dvd combo remote code
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
SOURCE: unervisal remote rca rcr321w for sylvania vcr/dvd
http://remotefinder.rca.com/default.aspx?site=rca
This link is what you are looking for
Posted on Dec 23, 2008
SOURCE: cant program dish network remote to my sylvania tv/dvd combo
Not likely will your current remote ever have the capability for your newer model.
The code sets are designed into the Dish remote as they were available then and don't 'learn' newer sets.
You might try to find one of the other Funai brand code sets under these names:
Funai, Symphonic, Emerson, Aventura, Durabrand,
ESA, Magnavox, INSIGNIA, and Misakai
Even if you do find one that gives you some functions, I doubt you will find one set for both TV and DVD player so you will have to try individual code sets; one for TV, another for DVD.
Posted on Jul 12, 2009
SOURCE: i have the SYLVANIA LD195SL8 tv dvd monito combo....
hi! i have a couple of codes for your tv, just try them hope this helps! goodluck! 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, 1150, 2092, 1464, 2408, 1465, 2260, 1046, 1465,1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483
Posted on Jun 07, 2010
Jul 27, 2018 | Sylvania Televison & Video
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
Feb 25, 2011 | One For All URC-3021 Remote Control
Mar 05, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Nov 26, 2009 | One For All URC-4021 Remote Control
Apr 02, 2009 | Televison & Video
Jan 26, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Jan 07, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
41 people viewed this question
