Radio Communications Logo
Question about Radio Communications
Can you change a gme marine radio 27 MHz to cb
Posted by Faye Osborne on
3 Related Answers
Anonymous
SOURCE: Freq change GME GX300 from 27Mhz to 29Mhz
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Posted on May 05, 2010
emissionwiz
Marvin
  • 85242 Answers
SOURCE: how u dim the lcd screen on a gme gx300 26 mhz cb radio
You have this posted in the wrong product category please re-post the problem in the right place. Thanks
Posted on Apr 27, 2012
clives40
Clive Pearson
  • 85 Answers
SOURCE: GME 275A Circuit Diagram
http://www.eeserviceinfo for manuals circuit diagrams free
Posted on Jun 28, 2014
Testimonial: "Many thanks for your help Regards Anske VK4CAB"
1helpful
Gme tx3800 cb radio not working
Martin-
Contact Get Support for more help.
Mark
Motorola Mobility Support
Tabla de frecuencias
CB Radio Channels (FCC)[32] Channel Frequency Channel Frequency Channel Frequency Channel Frequency 1 26.965 MHz 11 27.085 MHz 21 27.215 MHz 31 27.315 MHz 2 26.975 MHz 12 27.105 MHz 22 27.225 MHz 32 27.325 MHz 3 26.985 MHz 13 27.115 MHz 23 27.255 MHz 33 27.335 MHz 4 27.005 MHz 14 27.125 MHz 24 27.235 MHz 34 27.345 MHz 5 27.015 MHz 15 27.135 MHz 25 27.245 MHz 35 27.355 MHz 6 27.025 MHz 16 27.155 MHz 26 27.265 MHz 36 27.365 MHz 7 27.035 MHz 17 27.165 MHz 27 27.275 MHz 37 27.375 MHz 8 27.055 MHz 18 27.175 MHz 28 27.285 MHz 38 27.385 MHz 9 27.065 MHz 19 27.185 MHz 29 27.295 MHz 39 27.395 MHz 10 27.075 MHz 20 27.205 MHz 30 27.305 MHz 40 27.405 MHz
2helpful
Will talkabout 250 communicate with cb
No. Your Talkabout T250 operates on FM UHF frequencies between 460-470 MHz. The CB operates on 40 frequencies between 26-27 MHz.
Best regards.
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
3helpful
2answers
Sep 05, 2009 • Boating
3helpful
2answers
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
2helpful
Will it work with a cb radio
No. CB's operate at the 27 MHz on 22 predetermined frequencies allowed for Citizen Band radios; and your Motorola XV1100 radio is a VHF 150-170 MHz radio with a set amount of built in frequencies to choose from, designed for business use.
I Cant Pick Up Any Signals On my Cobra 25 LTD 40-Channels Base CB Radio all i hear is nothing. no truckers saying stuff. i just get white noise i do have an antenna. it is a tv antenna w/ bunny ears :) i...
Your problem is probably the rabbit ears. They are for tv in the 54+
Mhz and CB is 27 Mhz. For simplicity, go to Radio Shack and get a back of the radio indoor antenna. They run under $20. If you want to get more; try a roof antenna or a 1/2 wave cb marine antenna outside.
Hope it helps.3
Tom
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
